Need Help With Wiring Trailer Brake Control - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2012, 07:55 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
I have twisted my 300 lb body like a corkscrew to get under the dash of my recently acquired '98 C-1500. I am trying to get to the brake light switch to connect to the 'cold side' to wire to my trailer brake controller. I spent probably 15 minutes (seemed like longer) and did not find the switch. I would be happy just to find the wires going to the switch. Please, for the love of God, can anybody point an old fat man in the right direction ? Big Al
Old 03-22-2012, 08:12 PM
vicariouslynova's Avatar
CHEVY OR BUST
Big Al
Hey AL,
I just went and looked at my 97 Burb, I didn't see mine either, however My controller is hooked up to a white wire in a 9 prong plug, if you want email me and I can send you a couple pics. mhigh3@gmail.com
Old 03-22-2012, 10:09 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
I Took A Slightly Different Route And I Got It !
Every once in a while I manage to be just a little bit smarter than what I am working on. I located the brake light relay under the hood. I then determined which spade of the relay was power out. Then I took a 16ga. wire and stuck it in the spade socket in the junction block along with the power out spade. Added benefit of doing it this way, is that it keeps from putting any additional load on the brake light switch.
vicrod's Avatar
life is a ride
Last journal entry: 2014
Typically GM used the white wire from the brake light switch to the turn signal switch. This white wire can be found at the connector at the bottom of the steering column as the wires go into the steering column.
vicrod
Old 03-23-2012, 07:51 AM
Irelands child's Avatar
Why not do it the 'easy' way - and just go to AMAZON and get this wiring adapter
Wally World usually has them as well
I used to do mine the 'hard way' then found these and no longer needed to try to find a way to get my 220#/6'4" body under the dash .
Dave W
Irelands child
Old 03-24-2012, 05:20 AM
SSedan64's Avatar
Is that for Trailer Brake Controller or just a Tee for tying in Trailer Wiring at rear of Truck?
Old 03-24-2012, 07:56 AM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
That is the Tee for the light wiring at the rear of the truck. I a;ready had that. See my last post for how I found an easier way to get into the brake light circuit.
Old 03-30-2012, 10:18 PM
BigEd36's Avatar
I just tied into the wire at the back of the truck for a 3rd brake light for a bed topper.
Old 03-30-2012, 10:41 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Hooked up to the fifth wheel camper yesterday and towed it about 20 miles to a buddy's place for storage. Everything worked pefectly.
Old 03-30-2012, 11:05 PM
Wiki Edits: 31
That's how someone wired my '95 for trailer brakes too... I just have to get a trailer that can use it is all.
wiring car to trailer to many wires cares Electrical 10 05-14-2010 11:09 AM
trailer wiring ? lanier ledford Hotrodders' Lounge 2 09-26-2008 08:07 PM
electric trailer brake wiring at the axle curtis73 Electrical 3 07-17-2008 11:47 AM
trailer wiring brian12c Hotrodding Basics 7 09-13-2006 09:32 PM
wiring for trailer crownver Electrical 12 04-16-2006 01:09 AM
