need help wit selecting the correct cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2010, 03:38 AM
mtg mtg is offline
I have a SBC chevy400 with 327 double hump head with 202 valve
My tranny is a build turbo350 with shift kit 2800 to 3200 stall
I have a 4.56 gear, can someone please recommend me a compatible mechanical flat tappet cam.That will allow me great take off and top end speed.
Old 08-21-2010, 06:56 AM
what compression?
what tire diameter?
what car weight?
from the information given, I would say a cam similar to a compcam 294S would do ok. But the heads will require the correct springs for that cam (1.5" diameter preferred) and would require screw in studs and guide plates.
Furthermore, a cam like this requires a compression ratio between 10 and 11:1 cr, a Performer RPM dual plane intake or a single plane intake, headers, and dual 2-1/2 pipes.
the gear seems a little high if you plan to use regular size car tires. 4.11 gear would be better with tires 26 to 28 inch tall.
Old 08-21-2010, 09:52 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Depending on the exact measurements involved, your CR is going to be in the 11:1 range, give or take. This is too high for pump gas.
Old 08-21-2010, 12:03 PM
mtg mtg is offline
Tire 26*10.5-15 the compression is 11 to1 the weight I don't know it in a 83 old cutlass 442
Old 08-21-2010, 12:15 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Just what is it you have in mind for it? Daily driver, W/E cruiser, race only, or?
Old 08-21-2010, 12:29 PM
mtg mtg is offline
I'm building the car for racing only
Old 08-21-2010, 12:44 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I would use a solid cam- preferably a roller if the budget allows.
The Comp solid 454C10 mentioned would be one cam to take a look at. I personally don't often select cams for others, but I have no reason to think it wouldn't work for what you want to do.
Your heads will be the bottleneck- they need serious porting to make decent power. Your torque converter needs to be quite a bit looser, too.
Good luck.
Old 08-21-2010, 12:45 PM
ericnova72's Avatar
More for Less Racer
Ok, racing; but we need a lot more info.
Header primary pipe size, and length; collector size; intake type/style/brand/name; carb size and brand; rpm you are willing to turn (redline), approximate ET you want to run, car gutted racer or full street weight??
Old 08-21-2010, 01:02 PM
mtg mtg is offline
Yes header weiand team g intake wit open flange 4" tall the carburetors Holley 750 double pumper
Cam Correct Variable Cam Timing upstand2 Engine 27 08-01-2009 09:47 AM
Cam calculator strummin67 Engine 3 02-01-2007 03:05 PM
Which cam is correct? Forsaken502 Engine 4 09-09-2003 03:24 PM
IGNITION and CAM TIMING sum87mustang Engine 3 07-11-2003 07:52 PM
another cam ouestion...ie...cam timing VETTE GUY Engine 0 06-28-2003 11:29 AM
