Need help with zbar installation 65 Impala ss - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2006, 06:54 PM
I am converting a 65 Impala SS from an automatic to a mumcie 4 speed with a hurst shifter. I am at a loss how to install the zbar. Any help would be appreciated.
Joe
Old 09-05-2006, 12:52 PM
wrnchmaster's Avatar
not enough info!!
Old 09-05-2006, 03:13 PM
The clutch bellcrank, or "Z" bar is suspended between 2 ball sockets.
1 ball socket screws into a threaded hole in the engine block, and the other is mounted into a bracket that bolts to the car's frame, usually by 2 5/16" bolts.
JA
Old 09-05-2006, 04:02 PM
measure dist. betw. engine and frame, all parts availble from
GM
Old 09-05-2006, 10:12 PM
This is an early Camaro setup, but it should be similar.
value of 63 Impala SS hubcaps? akm Hotrodders' Lounge 10 02-04-2013 10:43 PM
68 Impala SS 327, is it a Muscle Car(tm)? 327ImpalaSS Hotrodders' Lounge 30 05-15-2008 09:25 PM
65 Impala, Hurst shifter macomml Transmission - Rearend 0 07-02-2006 07:47 PM
Can U Tell Me IF This Is A REAL IMPALA SS?? syclone477 General Rodding Tech 6 11-24-2005 05:07 AM
Fan Shroud for '65 BBC Impala SS Camarofiend73 Engine 2 10-05-2005 11:45 AM
