Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need hlp cant found what engine i got :(
Old 07-30-2012, 07:44 PM
oldbogie oldbogie is offline
Originally Posted by camaro1982 View Post
Hi all i got engine and cant found what kind is it dont know if you can hlp ?
casting# 3970010
engine code # MM01800
Its all i have hope some one can hlp me i wanna know how much hp i got :/
i have remove oil pan and i know its 4bolt main
Made in Mexico crate motor most likely it’s a 350 truck motor of modest cam and compression. Check the head casting numbers and get back to us. They're under the rocker cover about in the middle of the head. The 010 casting is a good heavy duty piece, check it out to see if it's been rebuilt. With some modifications these make a very reliable high output engine.
Bogie
