-   -   need hlp cant found what engine i got :( (http://www.hotrodders.com/forum/need-hlp-cant-found-what-engine-i-got-222356.html)
camaro1982 07-30-2012 06:47 PM
Hi all i got engine and cant found what kind is it dont know if you can hlp ?
casting# 3970010
engine code # MM01800
Its all i have hope some one can hlp me i wanna know how much hp i got :/
i have remove oil pan and i know its 4bolt main
350chevyrob 07-30-2012 07:03 PM
Well it ether a 327 or 350 you will need to get the suffix code off the block its on the pass side right above the water pump hole
camaro1982 07-30-2012 07:26 PM
there is no suffix on its all gone :( only thing there is the engine code MM01800 this can hlp ?
oldbogie 07-30-2012 07:44 PM
casting# 3970010
Made in Mexico crate motor most likely it’s a 350 truck motor of modest cam and compression. Check the head casting numbers and get back to us. They're under the rocker cover about in the middle of the head. The 010 casting is a good heavy duty piece, check it out to see if it's been rebuilt. With some modifications these make a very reliable high output engine.
Bogie
camaro1982 07-30-2012 08:08 PM
got it 3998993
DoubleVision 07-30-2012 09:33 PM
As Bogie said it's a Target Master replacement crate motor manufactured by GM of Mexico.
oldbogie 07-31-2012 10:09 AM
Originally Posted by camaro1982 (Post 1578683)
got it 3998993
These are low compression 75 cc open chamber heads originally used for 1968 through 1979 production, but they have soldiered on in the Goodwrench/Targetmaster crate motors.
Bogie
