need hlp cant found what engine i got :( - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2012, 06:47 PM
Hi all i got engine and cant found what kind is it dont know if you can hlp ?
casting# 3970010
engine code # MM01800
Its all i have hope some one can hlp me i wanna know how much hp i got :/
i have remove oil pan and i know its 4bolt main
Old 07-30-2012, 07:03 PM
350chevyrob's Avatar
haulin ***** and suckin gass
Well it ether a 327 or 350 you will need to get the suffix code off the block its on the pass side right above the water pump hole
Old 07-30-2012, 07:26 PM
there is no suffix on its all gone only thing there is the engine code MM01800 this can hlp ?
Old 07-30-2012, 07:44 PM
casting# 3970010
Made in Mexico crate motor most likely it’s a 350 truck motor of modest cam and compression. Check the head casting numbers and get back to us. They're under the rocker cover about in the middle of the head. The 010 casting is a good heavy duty piece, check it out to see if it's been rebuilt. With some modifications these make a very reliable high output engine.
Bogie
Old 07-30-2012, 08:08 PM
got it 3998993
Old 07-30-2012, 09:33 PM
DoubleVision's Avatar
As Bogie said it's a Target Master replacement crate motor manufactured by GM of Mexico.
Old 07-31-2012, 10:09 AM
got it 3998993
These are low compression 75 cc open chamber heads originally used for 1968 through 1979 production, but they have soldiered on in the Goodwrench/Targetmaster crate motors.
Bogie
Finally found the engine for me-454 benshelton383 Engine 12 12-01-2010 12:03 AM
Rare Engine Found OLNOLAN Hotrodders' Lounge 6 09-07-2009 07:23 AM
blower engine found $7000 mopars69 Engine 9 05-07-2008 05:57 PM
Car Skipped than Died? WHY? HLP calimstng66 Engine 3 11-22-2004 05:30 AM
I Found My Engine and a great deal! Chevelle71 Engine 1 02-27-2003 02:44 PM
