Need how-to advice - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2007, 12:13 PM
1953 Homer's Avatar
Homer is my '53 Ford
Need how-to advice
I want to add a drain plug to my transmission pan. (Too cheap to buy a new pan) I have basic welding skills but I want it to be "leak-proof". What is the procedure or is there a non-welded type that can be used?
Mike
Old 02-25-2007, 01:58 PM
BOBCRMAN@aol.com's Avatar
B&M and the other trans kit marketers, offer a trans drain plug kit that you insert into a drilled hole in the oil pan.
Old 02-25-2007, 06:55 PM
S10xGN's Avatar
Gotta love a turbo!
Yup, and I usually weld the female piece to the outside of the pan, then use the nylon seal and nut inside to make the seal. Now you can remove the plug without accidentally loosening the whole mess!
Russ
Old 02-25-2007, 07:34 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
IMHO, just drilling a hole in your pan and using a thread-cutting plug is looking for trouble.
GM used to (prob still do) make a weld-in 1/2" STD tab for the engine oil pan which would likely work just fine for your trans pan.
NAPA also make a "bulkhead" style drain plug kit that threads together, which might be a bit easier than the weld-in reinforcement.
NAPA # BKP 704-1074
Buy either one of these, and you'll probably never have a problem with it.
Old 02-25-2007, 09:13 PM
Tribal's Avatar
THUG LIFE
I use a 1/2" fine tread bolt & castle nut for my drain plugs. I first find a good spot to put the plug where it wont interfere with anything inside the transmission, like the filter, manual valve linkage, wiring, etc. Then I take the castle nut & bolt & screw them together with the castle nut upside down inside the pan. Then I put six spot welds the castle nut on to the pan, I keep the cut out notches on the castle nut open for draining purposes. Then I remove the bolt & flat file the pan at the hole. I then use a banjo washer on the bolt & tighten it down. It costs about a dollar in parts if I get enough to do 5 or more pans.
Just did a TBI conversion and need some advice ghomer Engine 8 12-28-2006 07:16 PM
Used compressor checks - advice? BeeTX Garage - Tools 10 12-21-2006 01:52 PM
replacement pickup truck - your advice please jojo99 Hotrodding Basics 7 05-03-2006 10:52 PM
replacement pickup truck - your advice please jojo99 Engine 3 04-28-2006 04:48 PM
replacement pickup truck - your advice please jojo99 General Rodding Tech 6 04-28-2006 01:18 PM
