need how to schematic for adding relays to headlights - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2012, 01:16 PM
hi i have a 1972 Riviera that i've added the newer headlights to. the headlights when on high beam flash so i would like to add 2 relays one to the low beams and one to the high beams i need a how to and schematic to show me how to do this thanks
Old 04-06-2012, 02:21 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
See attached for relay controlled headlights.
vicrod
File Type: pdf 004pdf headlight dimmer control (2) automotive relays.pdf (20.2 KB, 192 views)
Old 04-06-2012, 03:40 PM
adding headlight relays
thanks looks rather easy i'll give it a try
Old 04-06-2012, 05:04 PM
vicrod's Avatar
life is a ride
I'm curious as to why are you adding relays to the headlights?
I would think that new headlights draw less amps than the old style.
vicrod
Old 04-06-2012, 06:06 PM
adding relays
my headlights flash off and on on high beam and everything i've read the newer style headlights xeon draw 2 to 3 times more and the easiest and safest fix is to add relays so thats what i will do with help from sites like this
Old 04-06-2012, 08:44 PM
I used this relay.
Go to summit racing website, and enter KC3300 in the search box. It has two pin 87 terminals, so you can avoid making a "Y" splice in the wire going to the headlights
I wired it like this.
I got a relay box out of a late model car at a junkyard, and put the relays and new fuses in it.
Old 04-06-2012, 10:48 PM
Thanks Danielc i'll give it a try
vacuum schematic 79CaballeroMan Hotrodding Basics 1 11-23-2009 09:08 PM
Relays on headlights kleen56 Electrical 38 04-26-2009 05:24 PM
Adding a relay to the headlights junkyardjeff Electrical 4 09-24-2006 06:54 PM
Adding Fan Relays Didn't Help Maintain System Voltage JohnTN Electrical 3 05-22-2006 03:06 PM
Schematic Drawings johny chon Hotrodders' Lounge 1 01-07-2003 10:41 AM
