Need Hp Rating
2K views 27 replies 8 participants last post by  s10mannn
1990 s10 with 1988 355 bored 0.30 over edelbrock performer rpm intake manifold edelbrock 650 carb comp cams 470 intk 470 exhst 10 bolt 373 hyper pistons 9.3-1 compression full roller rocker arms. DOES ANYONE KNOW HOW MUCH HP ILL BE PUSHING?
#12 ·
OP, this question gets asked time and time again. The real answer is "Who cares?" How fast is your vehicle? What does it do in the quarter? Is there a HP level you must have to do a certain chore around the house?
If you really want to know how much power it makes, dyno it! Race it! Other than that, you're just guessing at a number to throw around at the next bench racing session at the local drive-in.
#13 ·
im asking because im spending about 3,000 on this i only 2,000 right now and im curious. i dont want to wait 2-3 months to dyno it. im 17 years old i dont yet know everything nor make bank to build it in one week and find out next week
#15 ·
I think I can come pretty close, I have dynoed 3 cars in last two months and one time there was a guy there just before me that had a 79 Camaro and he was saying he had about the same set up as you are saying but if I recall his cam was a hair bigger and it did have a little lope to it. but he called it a 383, not a 355- I have no clue the difference.
He ended up at about 245-255 HP, so would assume about a 300 net going through a 5 speed.
He just knew it was going to be 450-500 hp and was pretty pissed, his mistake was listening to his friends guessing HP.
#17 ·
his motor is totally different, sure its a sbc but not even in the same year range. anything below i want to say 87 ? will be different from mine
#20 ·
s10mannn said:
and a 383 and 355 have the same bore which is .30 over ...
I love it when a total noob comes here and lectures the people who are attempting to lend a hand.
Do yourself a favor and shut up and listen. Once you've been doing this for a year- or forty- THEN you get do some lecturing. Maybe.
BTW, you are TOTALLY wrong in your statement I quoted above.
#22 ·
383 uses the 400 crank and yes there is 383 that are bored and some are 383 that are not bored
#24 ·
and that wouldnt be possible for me considering my engine is 210-220 hoss power stock
