Need to ID a 305 or 350 engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2013, 04:30 PM
I got a 1983 Camaro to day guy told me it was a 350 NOT stock to the car. I'm trying to find out if it is really a 350 or a 305. I can not get to the back of the heads to check them number or the back of the block. Their is all of 1/2 inch of room behind the engine.
Their is no number on the front of the heads or on the front of the motor at all. I can not get to the side of the block to see if their are any numbers ether.
I have read online that the harmonic balancer/damper is bigger on a 350 thin 305 but their interchangeable.
Besides breaking the motor down or pulling the motor is their any other way to tell if its 305 or 350.
It wont help but the intake is a gm cfm 14057053.
Old 06-22-2013, 04:40 PM
Banned
pull a valve cover and get the numbers that are on the head and run them.
Old 06-22-2013, 05:05 PM
Well after a very hard time I got some numbers off the back of the block which are 1401020 I guess their is a number missing but even with that many numbers its a 305.
Why do people have to lie.
Old 06-22-2013, 06:15 PM
Banned
they lie cause it is all about the cash. Next time slow down do the research first then put up the cash!! Caveat Emptor (Buyer Beware)!
Old 06-22-2013, 07:07 PM
techinspector1's Avatar
Wiki Edits: 326
This is where you need a good strong flashlight and a mechanic's mirror......
Titan 11160 Telescoping Inspection Mirror - Amazon.com Titan 11160 Telescoping Inspection Mirror - Amazon.com
On all Gen I chevy motors, there is a stamped alpha-numeric identification on the PASSENGER SIDE BLOCK DECK, just in front of where the cylinder head ends. The number will be there if the block has not been decked and thus removed by a machine shop. Sometimes it is behind/under the alternator or other accessory that is hung from the end of the cylinder head.
Old 06-22-2013, 08:13 PM
well I guess ill part it out cant get T-tops any more someone will want a lot of these parts Not the 305.
Old 06-22-2013, 09:55 PM
Northstar T's Avatar
Gone sailing
I got a 1983 Camaro to day guy told me it was a 350 NOT stock to the car. .
Yup. and every SBC is out of a Corvette.
Russ
Old 06-22-2013, 10:43 PM
life is a temporary assignment
Russ
I heard that one more then once...
Old 06-22-2013, 10:45 PM
305cid block from a 1980-1984 car or truck..
Old 06-22-2013, 10:49 PM
The part im hating most is I text the guy and told him I ran the block number and its a 305.
The guy text back NO its a 350.
LOL WTF I had to give it to him like he was slow THE BLOCK ID NUMBERS RUN AS A 305.
I really like the its not stock part and the block numbers say 80-84 chevy mostly in Camaros BONE STOCK ALL THE WAY.
Old 06-23-2013, 08:48 AM
RWENUTS's Avatar
Did ya know if the last number you can't see is a 7 or a 9 it could be a 350.
Search Results for '1401020' - CastingNumbers.info: Numbers for blocks, heads, and more
Old 06-23-2013, 01:07 PM
14010201 its a 1 305 I was hoping to be a 7 or 9 today when I looked at the last post but its not.
Old 06-23-2013, 06:38 PM
Richiehd's Avatar
JS-70
Every 350 I ever bought was 4 bolt main out of a Corvette or a Z28........until I checked. As they say"Buyer beware"
Old 06-23-2013, 07:49 PM
Banned
can't get t tops, did you even try, 3rd gen f bodys litter junkyards
Wich heads do you recommand for OFFROADING -305 or 350 on a 350 engine? offroader9 Engine 1 04-07-2010 02:07 AM
engine swap 305 to 350 Brutalshame Engine 1 01-16-2006 07:41 AM
Engine Problems 305 or 350 CaMaRoMaN_79 Hotrodders' Lounge 6 10-14-2004 09:37 PM
How to tell if engine is a 350 not a 305 Meka Engine 14 06-16-2004 06:07 PM
350 to 305 engine swap jrm123180 Engine 10 03-28-2004 05:03 PM
