Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need to ID this rear differential and gear ratio
Old 07-14-2012, 10:54 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
X2^^.
Only aftermarket ratio I've seen available is 3.38
GM 55T rearend.
Differentials: GM 55T - Drops out the front of the housing in attition to having a 12 bolt rear cover. Uses c clip axles. Ring Gear Bolts: (12) 3 8 x 24 RH
The Following User Says Thank You to SSedan64 For This Useful Post:
