Need to ID this rear differential and gear ratio - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2012, 03:44 PM
dirtyfingers's Avatar
The pictures differential are of a rear end in a 62 chevy stepside, if i don't know what it is I cant find the gasket. I want to take off the cover and count the ring and pinoin to see what it is. Also how can I tell if it is a limited slip or a posi. or neather? any help out there?[IMG]C:\Users\aaron\Pictures\62 differential[/IMG] I tryed to get the pictures to come up but noda, I guess I don't know what the url is. The pics acn be seen in my profile albums.
Old 07-14-2012, 03:56 PM
big gear head's Avatar
High Performance Rear Ends
Limited slip and Posi are the same thing.
Old 07-14-2012, 04:04 PM
do you see the pics in my profile? What is the rear end make ?
Old 07-14-2012, 04:17 PM
rear end
I just marked the tire and the drive shaft the driveshaft turned two times around for almost exactly one time around for the tire, can this tell me anything about the gear ratio.
Old 07-14-2012, 04:32 PM
The make of this rear end
Finally i was able to upload pictuers can someone tell me what this rear end is so i can get the cover off and get a gasket.
ID:	66763   Click image for larger version
ID:	66764   Click image for larger version
Old 07-14-2012, 04:53 PM
That's the old truck rear end that was used from somewhere in the mid '50s. Sorry, I can't tell you much more than that. I haven't been into one of those before. My brother has the same rear end in his '57 truck. I think it was replaced by the truck 12 bolt around '64.
If you only turned one wheel then you only got half of the gear ratio. If you leave one wheel on the ground and turn the other wheel exactly 2 full turns and count the number of times your driveshaft turns that will be your gear ratio. If it turns just past 4 times then it's a 4.11, if it turns just past 4 1/2 times it's a 4.56... Those old trucks usually had gear ratios in the 4s.
A popular swap for those rear ends is the '67 to '69 Camaro or '68 to '79 Nova rear end. I'm pretty sure that those truck rear ends are right at 60 inches wide, which is what the Camaro and Nova rear ends are. This will also get you the smaller 5 bolt pattern for the wheels.
The Following User Says Thank You to big gear head For This Useful Post:
dirtyfingers (07-21-2012)
Old 07-14-2012, 10:54 PM
SSedan64's Avatar
X2^^.
Only aftermarket ratio I've seen available is 3.38
GM 55T rearend.
Differentials: GM 55T - Drops out the front of the housing in attition to having a 12 bolt rear cover. Uses c clip axles. Ring Gear Bolts: (12) 3 8 x 24 RH
The Following User Says Thank You to SSedan64 For This Useful Post:
Old 07-14-2012, 10:55 PM
the make of this rear
Insted of a swap, can I make this differential into a limited slip? And if so, can I change the gear ratio ?
Old 07-14-2012, 10:59 PM
I don't k know of any parts that are available for that rear end. I just don't have any experience with it.
Old 07-14-2012, 11:03 PM
rear end
I forgot to add, the axle is in place and I would rather not have to make another fit . By checking, it's a open rear and would like a limited slip.
Old 07-14-2012, 11:09 PM
rear end
Well I will just keep looking because it's under the truck so well. I would hate to start cutting and welding. Thanks for the help, maby someone will see this and have a solution.
Old 07-15-2012, 06:24 AM
poncho62's Avatar
Wiki Edits: 5
Take the cover off and count the teeth.......use gasket maker |(come in a tube) for a gasket
Ontario Rodders
The Following User Says Thank You to poncho62 For This Useful Post:
Old 07-15-2012, 07:51 AM
Hy, SSedan64 Thanks man, went to that link,will give them a call. would be nice if thay had limited slip to drop in, look's like the same and it was my year. Even if I had to fork out the dollars for a hole pig, it might fit onto the tube's. thanks againe
Old 07-21-2012, 04:35 AM
SSedan64's Avatar
There just isn't many parts for that 9.375" 55T Rear. No aftermarket Posi Carrier.
http://www.tomsdifferentials.com/201...og/Pages13.pdf
A complete Rear swap, GM 8.875" 12-Bolt, GM 8.5" 10-Bolt or 9" Ford would be the best option.
Old 08-05-2012, 12:43 PM
I did some checking and I was able to find a 3.38 gear for this rear end. I don't know of any limited slip differential for it, but you can change the gears to something that is a little better on the highway.
dirtyfingers (08-05-2012)
Rear gear ratio ? newportman Hotrodding Basics 3 02-14-2011 08:04 PM
Finding the rear differential ratio American Muscle Transmission - Rearend 6 01-12-2011 11:10 PM
rear end gear in differential? inrc Transmission - Rearend 6 01-11-2011 04:52 AM
Rear end gear ratio change = spedo. cable gear change. help? turbo 350 sugar ray Transmission - Rearend 6 07-18-2007 11:32 AM
Determining gear ratio on an "OPEN-differential, GM 10-bolt NASCAR314 Transmission - Rearend 6 11-07-2002 08:25 PM
