Need info on 96 Pontiac GP transmision - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2007, 09:41 PM
roddinron's Avatar
Sorry about the second post, but I posted in the engine area titled STRANDED, concerning my daughter 3.1L 96 Pontiac Grand Prix. She was told by a mechanic friend that these trannys (auto) can go and cause the engine from turning. Something about the transmission having a front half and a back half, and if the front half goes it can lock the engine? Does anyone know if this is true?
Old 04-07-2007, 10:03 PM
Crosley's Avatar
Wiki Edits: 1659
I would look at engine problems.
I do not see how the auto trans would seize the engine up.
I guess the converter could break up inside and bind up the engine against the splines of the stator support.
Old 04-07-2007, 10:10 PM
roddinron's Avatar
Well that's what I though, but I'm not too familiar with FWD and her mechanic friend says it's fairly common on these cars. New one on me though.
Old 04-07-2007, 10:19 PM
Crosley's Avatar
Wiki Edits: 1659
well .... lets say the drive chain inside the trans breaks and wads up the works !! The input shaft will be bound up on the trans. IF the torque converter was still operating correctly the engine should spin over.
The trans oil pump is shaft driven out of the converter. if the shaft breaks , the pump does not turn. That should not bind up the engine from turning by the starter.
Old 04-08-2007, 08:25 PM
airworld2's Avatar
96 gp
what kind of trouble are you experiencing ? no engine start? no power from a stand still trying to grain road speed? no gear change in drive from a stop?
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
Pontiac GP 400 ci - sm/bg block? voodoosurfer Introduce Yourself 1 09-07-2004 06:03 PM
Pontiac head # 6x info needed for 455 cu.in D.Cantrelle Engine 6 09-03-2004 07:13 AM
Pontiac engine spark plug info D.Cantrelle Engine 0 06-01-2004 06:36 AM
Info on 68' pontiac firebird 10-bolt rearend Adrenaline_Fiend Transmission - Rearend 6 10-17-2003 09:30 PM
