Need info Holley/supercharger 950cfm HP - Race Series ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2005, 05:39 PM
x007's Avatar
Supercharged T/A
Hi,
I'm not an Holley expert so need advice,
I have a Brand new 950cfm HP (the one a 650$+USD at summit) so i want to use it.., but i run a 410ci whit a F1 procharger, and if i'm right, a 750 or 800cfm should fit pretty well this engine.. But i have a 950HP thats a supercharger ready carb, to use...
I think its a bit too big for my engine, i have runned a bit whit the car that run fine and idle pretty well also but since all is new & i run a procharger on it the setup became tricky a bit.
I want to know if some experienced here have a good guess for the jet size to use on a 400/410ci SBC whit a 15/20psi boost on my 950cfm.
I'm pretty new whit the setup whit a supercharger, then using an AEM Lambda Meter for a precise air/fuel ratio also have a pyrometer, but as i can see when RPM going up the mixture became to rich a lot, at idle i'm pretty fine, but the supercharger can be the cause as well then create a rich mixture whit cranking since it compress more fuel.
Any help info appreciated..
I have already ordered some book about holley carb
to learn a bit on it but since the carb i have are already "race prepped" the only thing i may have to play whit is the jet size i think & may be the pump cam (i have a miss already when cranking), i dont know deeply holley carb so...
thanks.
Old 04-27-2005, 06:25 PM
lluciano77's Avatar
Short changed on common sense
The 950 hp is just a 750 double pumper with an 850 baseplate. They probably flow around 800 CFMs.
Old 04-27-2005, 07:26 PM
x007's Avatar
Supercharged T/A
Thanks for the info,
Any sugg. or range about jet size to use on 410ci / supercharged ?
Old 04-27-2005, 09:52 PM
lluciano77's Avatar
You got me there. I have no experience tuning a Holley to a forced induction set up. You will have to see what the engine wants. There are a few supercharger books out there that looked pretty good. Those might get you a baseline to start out with.
Old 04-28-2005, 06:29 AM
x007's Avatar
Supercharged T/A
ok thanks , i guess i will order a kit of jet for holley.. will be easyer like this i think...
Thanks !
Old 04-28-2005, 07:25 AM
willys36@aol.com's Avatar
Wiki Edits: 21
This is Holley's REAL 950!
Old 04-28-2005, 11:55 AM
x007's Avatar
Supercharged T/A
Here is mine 950HP Race series ;
Old 09-05-2005, 10:58 AM
Hey X007, Just wondering what you thing of that 950 hp. I'm considering buying one and I really have no input on how they perform.
Thanx.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
building race car need help with hp hotrodchevy General Rodding Tech 4 11-05-2003 10:17 AM
