Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need info ona a rearend
Old 10-07-2003, 02:15 PM
TooMany2count's Avatar
TooMany2count TooMany2count is offline
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
here ya go
you can put anything under it that will fit, so take a tape measure to the rear end & measure from backing plate to backing plate & from the surface where the wheels bolt on from one side to another & then check this page out to see what may fit............joe
