need info on steering box - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2009, 07:22 PM
hi guys was wondering if any of you know about Ford steering boxes I have a 1953 Ford Mainline and it has a little play in the steering i have been told there is some adjustment in them but on the top of the steering box there are two bolts i have been told that one is for oiling and one is for adjustment and i need to know which one is which thanks for any info.
Old 08-19-2009, 05:57 PM
fast68's Avatar
likes chevy trucks & boobies
one with a stud with a nut around it is the adjustment
but dont go crazy with it because it will cause stuck or sticking in center steering position if you tighten it very much
if the box is that worn you will want to get a new one
adjusting it is not very recommended
it is super old and worn and probably beyond its regular service life surely by now
so..
Old 08-19-2009, 06:22 PM
Wiki Edits: 31
unlike newer vehicles ( by newer I mean '55 or so and later ). the old boxes typically require adjustment... typically there are 2 adjustments.. over/ center and the worm gear adjust.. over center is what you will need to adjust.. it's a Gemmer box on that era Ford, so you'll see a jamb nut on what looks like a stud.. center steering, disconnect drag link and check to see just how much play you got ( wiggle the pitman arm ).. then loosen the jamb nut and you can turn the eccentric on the other side and rotate it in to adjust it, until you'v got just a slight bit of play and lock it down and reassemble
Old 09-03-2009, 09:11 PM
Steering Box
I HAVE A 53 MERCURY & I PUT A P/S BOX FROM A 1988 ISUZU TROOPER
IN MINE & IT FIT REAL NICE.I ALSO TOOK THE PITMAN ARM FROM THE
ISUZU & BELIEVE IT OR NOT BUT THE PITMAN ARM EVEN FIT THE DRAG LINK.
IF YOU DECIDE TO GO THIS ROUTE MAKE SURE THAT YOU TAKE THE HOSES
& THE P/S PUMP.IT WORKS OUT GREAT I LOVE IT.OTHER P/S PUMPS THAT WILL WORK ALSO ARE
AMIGO-89-93---PASSPORT-94-97
PUP (isuzu pick up) 88-95------TROOPER-87-93
Steering Box Adjustment Custom10 Suspension - Brakes - Steering 10 06-12-2009 10:45 AM
Question on 66 Mercury Comet steering and brake issues....... onebadmerc Suspension - Brakes - Steering 5 01-11-2007 05:41 PM
Steering Box Question SKULLNICK Suspension - Brakes - Steering 1 01-08-2007 10:44 PM
steering box blew its seals....78 nova snod83 Suspension - Brakes - Steering 7 11-01-2005 11:52 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
