Need input on 49 Chevy Truck build
Long time lurker here and have a new project for input:
49 Chevy truck cab Concept: * Quick/good handling chassis suitable for licensed street use as well as occasional autocross events. Think C6 killer in a 49. * Open wheel vehicle. Rat roddish style cab - chopped, patina but solid/straight with good workmanship. Minimal hood/grill and bed will also be minimal - sides and tailgate but with open floor. Chassis/interior/engine detailed. * Strong but tractable/reliable engine - 300hp SBC. Engine located as far rearward as possible and still practical. * Approx. 100-105" WB. Maintain weight about 2500lb. * As close to 50/50 weight distribution as possible. * Reasonable budget. Current plans. * IFS with solid rear and adjustable coilovers front and rear. Power steering. * Boxed S10 Frame (?) * SBC - carb'd/mild cam/headers/head work. * Trans - undecided if prepped auto or manual. (?) * Rear diff - have access to a gen4 firebird 3.42/posi/discs (?) * Tilt column (already have) * Corvette C6 wheels - 18x8.5/19x10 (already have) * Recaro style seats/4 points (already have and from a foreign mfr'r not to be named). * Fuel cell * Battery (rear located) * Radiator - rear located. (?) Thoughts/questions that come to mind: Is there another chassis I should be looking at besides the S10? The S10 is a pretty common swap on the Chevy AD body and reports are some decent handling vehicles can be made but I am not committed yet. With the positive offset vette wheels, I am pretty sure I am going to have to run spacers to keep the tires off the frame which I don't like. If I go with a wider rearend such as the WS6, I think I will be ok w/o spacers but the front will still need attention. Is there a more suitable chassis I should be considering or other options? Is there a better/other rear diff you would recommend? Anything I do will required some custom fab for coilover mounts/locating/etc. which I am fine with doing. Other thoughts/input? THANKS! |
Not my cup of tea but I would say what you want would be best done by making your own frame- s-10 is common for vehicles that have stock body
setup. You could use vette suspension and brakes, move the body to where you would get the weight distribution you want, have a much stiffer frame and probably spent no more than a cobbled together s-10 frame. Good luck with your vehicle. Jim |
Thanks Jet,
I had been considering going that route and as of last week am now the owner of a salvage C4 corvette. I am now wondering if it is better to cut the front and rear subs and link with a custom frame or build a new frame altogether. If I go the subframe route, I would prob just leave the track width the same but obviously need a narrowed midsection. Has anyone narrowed or seen a narrowed C4 chassis? |
| All times are GMT -6. The time now is 04:24 PM. |
