Need Intake Purchase Advice - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-06-2010, 05:59 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
All you need is the Holley #2732 plate. It's cheap, too.
  #17 (permalink)
Old 07-06-2010, 07:05 PM
sqzbox's Avatar
My pipes are my music
Shines how? In a milage test? I find it hard to believe that the small primary's of the q-jet can pass the same CFM as the larger primary's of the holley square bore. In my test with a 600 edelbrock, 600 holley, and whatever size Q-jet that came with my engine, the holley won hands down with my combo.
My 1850-2 was re-built by me to factory specs. Nothing special only diff. was the 1" spacer.
  #18 (permalink)
Old 07-06-2010, 07:22 PM
Hippie's Avatar
Last journal entry: HEI comparison.
Originally Posted by sqzbox
Shines how?
Zinc plated.
  #19 (permalink)
Old 07-07-2010, 07:08 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The Q-jet has very sensitive boosters. It is because of them, plus the diminutive size of the primaries that the Q-jet has the potential for "better" MPG.
Primary Flow for the Q-jet
175 to 185 CFM for 750 CFM Q-jets
210 to 225 CFM for 800 CFM Q-jets. The 225 CFM figure is only for the one-year '71 Pontiac 455 HO high-flow 4M Q-jet. It retained the 1-3/32 venturi, but lacked the outer velocity boosters found in all other models.
  #20 (permalink)
Old 07-07-2010, 07:20 AM
Cobalt
Would you use a gasket on each side of that plate?
  #21 (permalink)
Old 07-07-2010, 07:24 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by jmichaelre
Cobalt
Yes sir, I would definitely. It comes w/at least one gasket, another can be easily bought or made from a spare piece of gasket material if need be.
  #22 (permalink)
Old 07-07-2010, 07:26 AM
sqzbox's Avatar
The ad on edelbrocks site says "gaskets included". so I would assume that it comes with one for each side. Steel doesn't seal.
  #23 (permalink)
Old 07-07-2010, 07:58 AM
that it does....and its cheap i'll have to give it a try...
Oil consumption due to possible sucking oil from intake valley..signs ? y2k600f4 Engine 10 07-31-2010 04:40 AM
Edelbrock Performer vs. Stock Intake crussell85 Engine 8 04-03-2010 08:34 AM
Torque link intake manifolds? xxllmm4 Engine 10 06-12-2009 07:20 AM
New, About to purchase a compressor, Advice Petree Dish Garage - Tools 27 04-13-2009 05:44 PM
Intake port matching AFR heads 406chevelle Engine 2 01-16-2004 05:26 PM
