Need a junkyard ECM: Where is it located? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2012, 11:54 PM
Vetteman61's Avatar
Last journal entry: Moving my Journal
Hello,
I have a 5.3 LS1 from an 03 or 04 Chevy truck. I was supposed to get an ECM with this motor but never received it. I'm going to go to the local pull-a-part and try to find another one but I don't know where it is located in the truck. Does anyone know? Is there anything I should try to look for to make sure I get a good one?
Thanks,
Brandon
Old 03-28-2012, 05:40 PM
under hood...on left fenderwell, low, to the right of the battery and fusebox.
Old 03-28-2012, 07:08 PM
Vetteman61's Avatar
Thanks, I appreciate it.
Brandon
Old 03-28-2012, 07:22 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
BTW left = driver side.
You have a "pick a part" 'yard w/2003-2004 trucks in it?
where is the oil pressure unit located. kirkschopped67 Hotrodding Basics 2 01-15-2009 02:48 PM
cowl located steering box? gahi Suspension - Brakes - Steering 8 01-28-2005 08:44 PM
where are casting numbers located on chevy heads? smlblcks10 Engine 2 12-08-2003 11:59 AM
located new ford p/u 42-46 cab corners biglee55 Suspension - Brakes - Steering 1 11-29-2003 01:56 AM
box located on back of gauge cluster spankthru Electrical 10 06-16-2003 10:18 AM
