-   -   need to know coil spring rate (http://www.hotrodders.com/forum/need-know-coil-spring-rate-103158.html)
runn141 11-24-2006 08:04 PM
can anyone tell me the actual spring rate of a front coil from 77 chevy 1 ton c30 dualie pickup 2wd? there what im using, 73-87 models
Deuce 11-26-2006 03:49 PM
It would be almost impossible to give a spring rate ... because there are a few different ones installed by GM ... at the factory. SBC, BBC and options all affect the spring rate that GM would install :)
Most any dirt track guy should have a spring checker ... and tell what the rate is they you have ...
johnsongrass1 11-27-2006 03:00 PM
Look on the net for a approximate spring rate calculator.
