need to know coil spring rate - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2006, 08:04 PM
runn141's Avatar
can anyone tell me the actual spring rate of a front coil from 77 chevy 1 ton c30 dualie pickup 2wd? there what im using, 73-87 models
Old 11-26-2006, 03:49 PM
It would be almost impossible to give a spring rate ... because there are a few different ones installed by GM ... at the factory. SBC, BBC and options all affect the spring rate that GM would install
Most any dirt track guy should have a spring checker ... and tell what the rate is they you have ...
Old 11-27-2006, 03:00 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Look on the net for a approximate spring rate calculator.
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
HELP….HELP info on Moog coil spring, Im running iut of time 406chevelle Suspension - Brakes - Steering 7 04-25-2004 09:39 AM
info on Moog coil spring 406chevelle Suspension - Brakes - Steering 0 04-22-2004 09:26 AM
4.3 V6 Coil Spring Rate Cecil Stainback Suspension - Brakes - Steering 4 10-30-2003 05:38 PM
Federal-Mogul #8542 Coil Spring Rate Bill Ford Suspension - Brakes - Steering 0 04-09-2003 06:36 PM
