Need to know how to wire a 60s S&W Greenline tach/sender - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2014, 04:56 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Can anyone tell me how to wire this? Just bought it on ebaY.
Old 07-07-2014, 05:04 PM
ericnova72's Avatar
More for Less Racer
Did you get the transformer box and battery box (took oddball 2 or 3 volt dry cells IIRC) that runs the tach?? Otherwise, there is no way to use it like a modern tach...it doesn't just use 12V+, a ground, coil neg- and a 12v+ lighting circuit like the modern stuff does.
You could Google search, there is a company out there that takes these old tachs and converts them to modern electronics while keeping the vintage case, face and needle.
Only reason I even know this is my Step-dad has the whole deal packed away in cotton from the early 60's Catalina he had.
Old 07-08-2014, 08:42 AM
Wiki Edits: 21
Never saw a battery box for one of these. I thought all it needed was the sender (red unit) that converted the signal. I have a copy of wiring instructions for a similar looking setup but the sender only has 3 screws, not the 4 on this one. I am thinking there is an extra 'Trans' terminal that isn't used? One trans to distributor, and '+/- ' to the tach. That's how the 3-wire diaram has it, w/o the extra screw, no battery box mentioned.
Old 07-08-2014, 05:26 PM
ericnova72's Avatar
More for Less Racer
The battery box version we have may just be a year or two older than yours, IDK...revisions happened pretty often back in those days, it was the infancy of add-on gauges and tachs industry back then.
Sorry I couldn't be more help??
Maybe someone over at the H.A.M.B. board may be better help??
Old 07-09-2014, 07:25 AM
Wiki Edits: 21
No problem. Yes I have seen several versions of transflormer boxes shown with what appears to be the same gauge on the front from that era. No problem, I am used to everything I get for my nostalgia projects being very obsolete w/ zero information available. Try finding a transmission rebuild manual for a Phord Cruise-O-Matic MX tranny some time!!
Old 07-15-2014, 02:32 PM
Wiki Edits: 21
You are correct, that red chunk is a battery box. What a dumb design even in the early 60s. They had plenty fo 12V power to work with and they went with batteries.
Videos/pics from the 60s & early 70s jimhennen Hotrodders' Lounge 1 12-03-2011 07:23 PM
How to wire up a tach?? sexypizzaman Engine 3 05-29-2008 07:27 AM
tach wire 03eiger Electrical 14 12-22-2007 10:36 PM
Wiring 4 wire tach cutsupreme Electrical 20 03-15-2007 07:39 PM
tach wire mhudak Engine 1 11-11-2004 10:10 AM
