need to know if t56 will match up and what rear end should i go with - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2006, 11:37 AM
Hello,
I'm wanting to know if it is possible to bolt up a t56 6 speed to a 2.3l ford engine. droping a 2.3l turbo into my 87 hatch mustang from a couger im going to be modifing the eninge looking at 300-400 hp. what will i need to do to make it match up? Will the companies that produce the t56 beable to make one for my car? anouther thing is i dont know which rear end size i should go with. im aiming for a decent acceleration and high end top speed. i know i want a limited slip diferenceal. But i dont know if i should go with a 9" or the 8.8" housing. not realy looking at takeing to track more for a personal car that is realy fast. thanks for any information so far this forum has been a great on help in turning my 4 cyl stang into a monster.
Old 03-28-2006, 11:15 PM
the t56 has a larger output shaft. and i dont think the bolt pattern is the same either. as well as the crossmember. as for the rear i would go 8.8 which is much cheaper and easier to find then the9'' and put a 3.73 gear in her hope this can help
Old 03-29-2006, 04:39 PM
thanks
hey thanks for the rear end information ill remeber it.ok since the t56 wont work is there anouther 6 speed manuel that will work. if not ill give up and change the gears. next car is deffinitly going to be a 5.0
Old 03-29-2006, 05:22 PM
any 6 speed is gonna have a large input shaft. i would stick with a borg warner 5 speed out of a mustang and have it regeared
