Need to know max time between base coat applications. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2008, 08:48 PM
I have an issue, I was told by a paint supply store that I would have enough paint for the base coat of the entire car by having 1 quart paint and 1 quart activator. Well I got one coat on but I still need 2 more coats. This is a problem because I painted the car on mid day saturday and I cant pourchase paint on the weekend due to the fact no local place is open. Is waiting 36 hours to apply another coat going to ruin my paint job? I've spent 3 months trying to get the prep right and I dont want to ruin it and have to restart. BTW this is only my second car I have painted and I'm using a dupont black with nason 2k urethane primer and hot hues semigloss clear from dupont.
Thanks for any input, I look forward to contributing as I grow in skill.
Old 08-24-2008, 08:59 PM
Dupont recomends recoating their Chromabase and Chromapremiere base within 24hrs. Check the tech sheet for the basecoat you are using on DuPont's website. I have done some major graphic jobs with DuPont that have stretched over a week long and never had any problems, I used DuPont 222S whenever I went past the recoat window.
Old 08-24-2008, 09:01 PM
Thanks for the timely reply. This advice is sure to make me a loyal member here, thankyou!
Old 08-24-2008, 09:17 PM
What if I didnt use an adhesion promoter? Its only 24 hours right now and I was gonna paint nine hours from now.
Old 08-25-2008, 05:03 AM
It will be fine IMO, just give the paint a couple of hours to flash off well before applying your clear. Black is the worst color for holding solvents because of the carbon pigment, so when you apply more coats that original coat is going to suck up solvent and then it all needs to evaporate back out before your clear goes on. Give it some good flash time before you clear and it will be fine.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
Not enough base under clear coat! shad9876 Body - Exterior 23 11-27-2007 05:35 AM
Base coat from SPI Don Meyer Body - Exterior 2 05-16-2006 10:55 AM
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 12:22 AM
Which type, base coat clear coat or.. Rubberman2003 Body - Exterior 20 12-19-2003 01:09 AM
