need a little help - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2007, 09:36 AM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
need a little help
i am currently putting the front suspension back together on my 66 impala. and im having a problem with the front springs. i rented a spring compressor and compressed the spring about 4 inches or so. it was compressed pretty good, i have the lower control arm bolted in and i have the spindle assembly connected at the lower ball joint. when i set the spring into the frame pocket and sit it on the lower control arm i am still about 6 inches short of mating the upper control arm to the spindle..... i kept compressing the spring until the screw was sticking out past the spring and hitting the underside on the spring pocket in the frame. but im still to far away. i think one of the issues is the fact that there is such a sharp angle on the lower control arm its hard to seat the spring properly until its all bolted together and its sitting assembled.
i took the compressor out and tried to reposition it so i could get more compression before the screw would stick out past the top of the spring but now im having a hard time setting the compressor it keeps slipping down the spring as i compress it so any advice would be appreciated thanks.
Old 10-07-2007, 10:21 AM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Remove the lower control arm and use a jack to put it back on.
Old 10-07-2007, 10:37 AM
helrazr3's Avatar
thanks, so i should assemble both ball joints and just remove the control arm from the opposite end ?
Old 10-07-2007, 10:44 AM
My 2 cents worth
Wiki Edits: 3
Yeppers. It's much easier that way.
Old 10-07-2007, 10:48 AM
helrazr3's Avatar
i figured there was somthing very simple looking me right in the face that would work...... thanks a lot for the help!!!!!
Old 10-07-2007, 11:01 AM
My 2 cents worth
Wiki Edits: 3
I forgot to mention that rear bolt is the camber adjustment bolt. Of course I'm sure you are going to get it aligned after your done.
Old 10-07-2007, 12:27 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Removing the opposite end of the lower control arm is certainly an approach that I wouldn't have thought of ...
I built myself a "spring compressor" using some 1/2" steel plate and a piece of 5/8" Grade 8 ready rod. The ready-rod went down through the center of the spring where it threaded into another piece of 1/2" steel plate. The ready-rod was lubed up with anti-seize ant the spring was compressed by tightening the nut up top. This takes a LOT of force ... and the threads on the nut want to gall up ... so use another "follower" nut as a safety.
I ended up getting the spring compressed about 1/2 way and safely "caged" using my "spring compressor". Then I just lowered the vehicle using a floor jack ... using the vehicle weight to compress the spring fully. After the nuts on both ball joints were tightened up, I un-threaded the compressor and removed it.
Old 10-08-2007, 10:08 AM
helrazr3's Avatar
yes im going to send it to a local (expert) in front ends lol the guy really knows his stuff.
thanks for the idea on the compressor.
