Need a little help to decide - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2005, 09:54 AM
Bluepen's Avatar
Just a firefighter
Last wiki edit: How to title a hot rod
Last journal entry: New rear rollpan installed
Wiki Edits: 2
The '46 Panel is almost ready for final paint now. But I started looking and might change the paint design and I would like some info on how or even if I should do it. Now keep in mind I'm not a painter or even claim to be but I've read, practiced and asked enough question that I'm sure I can paint this truck with only a few problems. I'll be using single stage urethane, because its easy for me to use. The only real question I have is how to mask this off really. What I want to do is paint the molded panel on the side of the truck a different color from the rest of the body. And I'm also thinking about the molded strip down the side. In the pic #1 is the panel and #2 is the strip. Also how long should I let the panel/strip dry before I can mask it off. I've also been told not to try and paint the whole body in one shot as the roof will dry before I get the coats done and end up with dry over spray on the roof so the strip will be a good break line for that.
http://hotrodders.com/gallery/showph...cat/500/page/1
Thanks
David
Old 08-31-2005, 10:00 AM
New Member
Last journal entry: '46 Ford coupe - engine buildup
Although I've never used it on a surface that large, I've used clear contact paper when painting bikes for years. Easy to cut, sticks great, and peels right off when you are done. Use a little wax and grease remover to get he adhesive off, and you are done!
Old 08-31-2005, 02:35 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
What brand are you using?
I've used the clear Contact brand which is like clear shelf liner from Home Depot and I will NEVER use it on a paint project again.
It took FOREVER to clean the adhesive off and lifted baddly around some tight curves on flame lick's and such,especally using Kandy's.
It may be OK for a short term "on the panel" time,but if it stay's on overnight or a couple of day's forget it. The paint has to be completly dry as well cause if it's still even a little green,it will track it up bad as well.
Cant decide to juice or bag!!! vatoloco63 Suspension - Brakes - Steering 10 07-05-2005 08:59 PM
How to decide the Hinge axis for car Door:) keshava Body - Exterior 5 07-20-2004 08:04 AM
decide my paint job. crazy larry Hotrodders' Lounge 13 01-22-2004 12:22 PM
Help me decide. 78 monte Hotrodders' Lounge 1 07-08-2003 12:29 PM
Any one have dyno software? I need to decide on a cam. Jared Engine 4 03-10-2003 05:54 PM
