Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need to lower comp. 383 sbc build
Old 12-11-2012, 11:19 PM
bowtiemike bowtiemike is offline
383 comp
You could always keep the comp ratio you have with a 64cc head and convert to E85 it really a simple procedure cost around 300.00 and you can run almost any comp ratio up to 15/1 and they are selling E85 at almost every speedway,meijers,costco. We are running a 14 1//2 to 1 383 on E85 and it runs awsome just buy the carb conv kit for 140.00 and for your build you could use a mechanical compatible fuel pump 120-140.00 or an allstar black with proper reg im building almost every street car that we run at this time to use E85 do some research Its def an option, MIke
