Need a M14x1.50 bung - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2012, 04:00 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Okay Im not really sure what section was best for this question but here we go. I am converting my car to an electric fan and am hooking up a fan switch into the radiator so the fan comes on by its own and I don't have to worry about forgetting to turn it on or off. I already have all the wiring done and have it wired to a dual fan relay from a volvo and just have it on a SPDT switch in the car. If you look in the header above my post and check out my last wiki edit this is what im doing. I already have the fan switch from rock auto. I have a friend that designs and welds radiators and said he would weld the bung on for me if I brought it to him... problem is I can't find one that is M14x1.5 which I believe the post says it is.... any ideas on a good place to look? google wasnt a lot of help and neither was amazon ebay summit or mcmaster.
Old 04-04-2012, 09:37 AM
S10xGN's Avatar
Gotta love a turbo!
Sounds like a spark plug thread, have you checked your local parts house for "plug savers"? You might also look at oxygen sensor bungs...
Russ
Old 04-04-2012, 09:41 AM
Listen and Learn
Wiki Edits: 7
Russ
I thought oxygen sensors were m18x1.5... but spark plug maybe? But I could be wrong
Old 04-06-2012, 08:41 AM
S10xGN's Avatar
Gotta love a turbo!
Depends on the plug, there are (or were?) different sizes...
Edit: Nevermind, I saw plug when you said oxygen sensor...
Russ
Old 04-06-2012, 05:09 PM
Why not put the switch in the engine?
vacumm bung? tinman386 Engine 2 03-29-2010 07:45 PM
stripped filler bung on rear differential murrsue Transmission - Rearend 6 07-08-2005 05:06 AM
O2 sensor bung placement/ manifold choice williambartram Engine 12 12-19-2004 12:31 PM
Making a bung fitting Jag Daddy General Rodding Tech 3 05-03-2004 08:38 PM
