need a manual instruction for a fairbanks manual no tranbreak valve bodie th-400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2008, 02:52 PM
hi, my name is bob and i am searching for the manual instruction for the FAIBANKS aluminum manual valve bodie no tranbreak for a th-400,
i bought this transmission used and i rebuild it for about 4 times rebuildit in the stock way, allways the first ring of the oil pump broken or the bodie weared where the 1st ring are, and then a broken ring,
DOES ANY ONE KNOW WHERE CAN I FIND THIS MANUAL INSTRUCTION ??
Old 09-20-2008, 03:05 PM
SSedan64's Avatar
You may be able to get a manual from Superior. Fairbanks is a division of Superior.
http://superiortransmission.com/products/products.htm
Fill out their Information request form online.
http://superiortransmission.com/prod...nce/400_ta.htm
Or physical address
Superior Transmission Parts, Inc.
3770 Hartsfield Road
Tallahassee, Florida 32303
Ph.#1-850-574-2369
700R4 Why are the TCI manual valve body instructions so lousy? Bayley Transmission - Rearend 24 02-16-2009 01:49 PM
Turbo 400 manual valve body Tbucit Transmission - Rearend 2 07-26-2006 09:38 PM
Turbo 400 Manual valve body Tbucit Transmission - Rearend 3 05-10-2006 10:30 PM
TH350 Manual Valve Question Pantload Transmission - Rearend 6 02-19-2006 02:48 PM
Turbo 400 with manual valve body & reverse pattern... Bumpstick Transmission - Rearend 5 12-26-2005 04:51 PM
