need measurement 1933 ply - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2008, 12:36 PM
have only body of 33 ply coupe..... i need measurement from outside to outside of front tires ......need to know max still fit inside of fenders......thanks ..........moremopars............
Old 04-24-2008, 01:07 PM
WELCOME to Hotrodders.com
As a Moderator here, I want to be the first to WELCOME you here
I have never owned a 33 Plymouth so I am off little offical help ... but I do know that the Plymouths and the Fords were very similar in size back in the 30's ... I use a 48 inch wide straight axle under my 32 Ford.
As you can see, the tires fit under the 32 pretty well ...
Old 04-24-2008, 01:15 PM
Bluejackets67's Avatar
In the WebRodder forum, they have a wheel & tire sheet that will help you figure this out. You'll need some measurments off of the fenders, wheel size and the tire size you plan on running.
Bias Ply tires....are they THAT bad? Motochris Suspension - Brakes - Steering 25 09-25-2015 04:22 AM
1933 5 Plymouth 5 Window Coupe LitlRedCorvett60 Introduce Yourself 4 10-07-2014 02:25 PM
Another 32 ford measurement from a 5w? F&J Body - Exterior 0 08-27-2007 09:39 PM
track width measurement streetrodder31 Suspension - Brakes - Steering 4 05-17-2004 06:07 AM
converting drum to disc on 36 ply tcampbell1 Suspension - Brakes - Steering 2 02-25-2004 01:39 PM
