Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need More Info On Piston Rings
Old 02-25-2006, 03:17 PM
Canadian Charlie's Avatar
Canadian Charlie Canadian Charlie is offline
The Big Money
Last journal entry: New Air Line Part 2
Ok I'll be filing my rings soon, got the filer, have the rings and I just need to ask a few more questions.
When I'm filing the rings is it just the top and second ring? Or the oil ring too?
Is the ring tool that is used to place rings on the pistons easy to use or do I have to be really carefull? Mine is a Blue Point
Do I line up the rings prior to putting them in the bores so the open end of the rings are not underneath each other?
Do I oil the piston up a little before I put it in the band compressor before sliding it into the bore?
Anything else I should know?
Thanks
