Hotrodders Bulletin Board > Tech Help> Engine
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 01-28-2003, 08:25 AM
ricekiller ricekiller is offline
Post need more power
i have a 1973 dodge dart with a 225 slant six.... i'm looking for ways to get some more power out of it.... i was thinking about either a turbo or nos.... i'm not sure if you have any ideas drop a line or two....
  #2
Old 01-28-2003, 08:39 AM
lookatme's Avatar
lookatme lookatme is offline
Post
Where do you want the power top end speed or lower end power? what have you already got in it?
what kind of gears are you running?
Old 01-28-2003, 01:10 PM
steppenwolf steppenwolf is offline
Post
go to the dump, look at a bunch of posts by a guy named slantsix. once you've recovered from the ensuing hysterical laughter... it's almost cheaper to go with a v8 than try to get much more power out of a slant six. you'd have to do some serious work to get real power, even with nitrous or a supercharger, and with a blower you're easily pushing v8 prices. good luck! if all else fails, just put a 4.86 rear end in, you'll beat most people stoplight-stoplight.
-z-
Old 01-28-2003, 01:28 PM
deuce_454's Avatar
deuce_454 deuce_454 is offline
Post
you should visit the JY-Turbo newsgroup on yahoo thost guys build turbo setups with home welded manifolds and junkyard turbos that put 2 HP pr cube easy and all for a pricetag of less than 1000 bucks for a twin turbo v8, blowthru, Nitrous will also add loads of power but like turbos it can produce way more power than your engine can cope with and kill an engine faster than you can let off the gas.. anyway good luck with it
Back to top
Search this Thread:
Advanced Search
vB code is On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
