Need new Carrier thrust washers - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2011, 04:05 PM
Were can one purchase new GM .31" thick carrier thrust washers for 10 bolt 8.2 differential?
Old 05-13-2011, 04:39 PM
BOBCRMAN@aol.com's Avatar
GM dealer or a good trans shop.
Old 05-13-2011, 06:27 PM
There is probably a driveline shop in your area that has shim kits which will give you any shim thickness you might want. I sell kits for $11.
Old 05-13-2011, 07:46 PM
prostreet6t9's Avatar
Differential/Driveline
Which thrust washers are you needing??
Side gear thrust washers: GM#40000160. These are actually for a 99 and newer 8.5 but are the same ID/OD. Not sure of the thickness though.
Pinion gear thrust washers: GM#1385734
Not a good idea to put a generic shim in these locations as the generic shims are not normally hardened and you could end up with a mess.
TH350 thrust washers/bearings DHMag Transmission - Rearend 2 12-05-2005 09:22 PM
Power Washers Canadian Charlie Garage - Tools 5 05-13-2005 11:02 AM
Reasonable Parts Washers LimitedKnowledge Garage - Tools 2 09-18-2004 06:10 PM
Where to get a set of Unilug washers and nuts to fit? Dubz Hotrodding Basics 1 07-06-2004 07:33 AM
Copper washers on the rearend? 52Caddy Transmission - Rearend 2 07-05-2004 10:51 AM
