Need new transmission. Any suggestions? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2012, 12:53 PM
77' Camaro
I have a 77 camaro. I just blew up the motor and have to have it replaced. I don't like the automatic transmission that is in it and wanted a 4spd. My stepdad said that muncie is a good way to go what would you suggest. I'm 17 and don't have a ton of money but my car needs to be fixed now so help me if you could. Cody
Old 09-18-2012, 08:33 PM
+4 speed Dad is right
Daddy is right find a good top loaded muncie and check the shaft bearings to make sure that the shafts are tight no play in them and I will bet it will outlast the car, jessedenny47
Old 09-18-2012, 09:28 PM
RWENUTS's Avatar
Daddy might be right but it'll cost you 2 grand by the time you find a good tranny, shifter, bellhousing, flywheel, clutch assembly, pedals and linkage, u-joints, driveshaft mods, tranny mounts etc. etc!!
I don't go lookin' for that super rare never built top loader muncie! No such animal.
Get a motor and a high stall convertor for your T350.
Old 09-18-2012, 10:09 PM
vinniekq2's Avatar
turbo 350 is not that expensive and can be set up to shift very fast. too expensive and time consuming to convert to standard unless you get a donor car cheap.If you insist on getting a standard,dont forget to install a pilot bearing,it cost me a muncie when I was 18. and muncies are not super tough,just tough.
Old 09-19-2012, 01:13 AM
Sorry muncie
I want to say I was mistaken there is no top loading muncie transmission. the one I was thinking of was a borge warner T-10 came with ford from about 1964-1974 although some fords came with one later inyears. I must say try a B&M full comp trans pack with the full comp valve body plate and governers plug and thid will give you almost the same as a four speed.
Old 09-19-2012, 06:58 AM
Both the T 10 and Muncie are side shifted.
To the OP: to get a Muncie guaranteed in good shape; is going to cost you over a grand; then you need a clutch/pressureplate, flywheel, clutch linkage, bellhousing, throwout bearing, perhaps a new crossmember. Lets not forget the pedals and any linkage there.
We just built a gearbox for a former Lemans car; new case, iron midplate, italian gears and synchronizers, everything new, not one Muncie OEM part; and it was $2275. I've seen our basic transmissions go used for 1200 bucks. I've also seen our Supercase filled with worn out original gear sell for a grand as well. You really need to know what you are looking at when you buy a manual trans; and I'd really hesitate to buy sight unseen because with your budget, you can't afford to get screwed, even if you have to pay a little more to get exactly what you want.
My advice? Get a TH350 or 700r4 core and rebuild it yourself; and save your money for the Muncie/T10 conversion. Plan on 2 grand unless you get a donor car or someone going to a 6speed.
The key to being a young guy with a hot rod is keep it simple, keep it basic and keep it running.
If you want to build your own Muncie; Start with a new Muncie case and go from there. I can help you find good used parts, or people who rebuild em using good parts
Old 09-23-2012, 07:58 PM
build a 350 and if you want mileage get a 700 r 4
the 350 could be set up to work for cheap 400$ rebuilt
Old 09-28-2012, 06:52 AM
Too Many Projects's Avatar
A few beater muscle cars
Last journal entry: continued
I'm with the majority here and encourage you to keep the current trans and save up for a conversion at a later date. If your current trans isn't in good condition, a rebuild of the TH350 is reasonable enough. I don't advise a 700-R4 as they require much conversion to fit your car and the cable adjustment is CRITICAL or you can burn up a new trans before you get to the end of the block. A 200-R4 is a bolt in swap to an overdrive auto and isn't as fussy as a 700.
Once the new engine is in and the tach gets to 5500 rpm.....shift...
Good luck on your project...
Old 09-28-2012, 08:12 AM
It hasn't been mentioned here in this thread, but I wonder if the OP would be a good candidate for a TH350C? Direct bolt in, cheap to rebuild, a little better economy than the T350 and without the TV cable geometry and associated brackets details of the 700r/200-4.
Thoughts?
Old 09-28-2012, 08:19 PM
I had to look that one up. I didn't know they existed. That could be a good alternative for many applications that want to drop rpm for mileage. I'm assuming it's still just a direct drive in 3rd but without converter slippage...
Old 09-30-2012, 07:46 PM
SSedan64's Avatar
Yes, Lockup TC in 3rd, no slippage.
Came in 80-86 vehicles.
Transmission Manf. Suggestions 65malibuSS Transmission - Rearend 1 05-24-2011 12:01 PM
64 Nova build.. suggestions on a transmission nobody1031 Transmission - Rearend 2 08-25-2008 06:31 PM
Transmission suggestions-383 in a 1600lb. car McDeuce Transmission - Rearend 3 11-07-2005 06:05 PM
Stall wrong, transmission shift adjustment, suggestions? frankenvette Transmission - Rearend 3 10-26-2004 11:59 AM
need HP suggestions 400ci Trans-Am Engine 9 09-29-2004 11:35 AM
