Need for an oil cooler - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2011, 09:30 AM
Ok i have a 496cid stroker with big aluminum heads (bigger valves, heavily ported), and solid roller cam with 712 lift, im going to be running a mechanical water pump, dual fans and an aluminum radiator.
heres my question is there any need to run an oil coooler?
motor is not running, or in the car so i dont know temps yet...
Old 01-05-2011, 09:57 AM
68NovaSS's Avatar
Wiki Edits: 9
Hard to tell right now. I had concerns with my blower motor, with the filter being nestled between the block and headers really close. I installed dual remote filters, moving them away, into the upper wheel well.
I didn't have a temp gauge, but knew things were heating up.
Old 01-05-2011, 09:58 AM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
if you are going to be running a remote oil filter you might as well add a cooler
if not, who knows, how good of a rad do you have?
i think its always better to have coolers if you can
Old 01-05-2011, 10:07 AM
68NovaSS's Avatar
Wiki Edits: 9
Sure, an oil cooler is ideal, depending on your needs, and I'm not against them. In my case, moving the filter was all it needed. I was able to somewhat monitor the temp with my laser temp gun, and it cooled quite a bit. Of course, there's a lot more involved in installing a cooler, but that shouldn't deter you if it's needed.
Old 01-05-2011, 10:11 AM
I don't understand?
we were both typing/posting to the OP at the same time
Old 01-05-2011, 10:14 AM
68NovaSS's Avatar
Wiki Edits: 9
Yeah, a guy could get hurt in the collision.
I grew up in Burien, a house right on the sound, sure miss that lifestyle...
Old 01-05-2011, 11:13 AM
Sick467's Avatar
Last journal entry: Wheels and Exhaust.
It's my opinion that oil coolers are only needed in race applicataions and more for racing that holds the engine at high RPM's for extended periods. I doubt that you really "need" one. All the cooling should be done by the radiator and an oil cooling system could keep the oil too cool which would not be good wrt engine wear.
If you are running an auto - put in a tranny cooler before considering the oil cooler.
Sounds like a nice engine btw.
Noel
Old 01-05-2011, 11:18 AM
I don't understand?
Noel
from the sounds of that engine build,even if your not at the track,ITS ALWAYS A RACE!
Old 01-05-2011, 11:40 AM
malc's Avatar
Born To Be Mild
I use a Derale thermostat inline with my oil cooler, letīs the oil get up to 170š
before it starts to go through the cooler, oil temp is better regulated.
Old 01-05-2011, 11:51 AM
I don't understand?
thats cool, learn about somthing every day
Old 01-05-2011, 08:59 PM
Thanks for all the info everyone! im leaning towards no oil cooler, due to engine bay room and my need for cleanliness under the hood, at least until its running properly and then i think i'll make a decision, its something that can always be added later.
BTW- its definetely gunna be a fun motor on the street, its a weekend warrior thats what there for!
Old 01-06-2011, 02:17 AM
malc's Avatar
Born To Be Mild
"Iīm leaning towards no oil cooler, due to engine bay room"
My coolers, engine and trans are in front of the radiator not in the engine bay, hot environment.
External Trans Cooler, Radiator Cooler, or both? 2004R & 383 SBC Cousin_Joe Transmission - Rearend 1 02-27-2008 09:10 AM
how much cooler msc66 Engine 7 09-06-2006 05:16 PM
Can I use a trans cooler only without a radiator cooler? supercab78 Transmission - Rearend 5 04-14-2005 01:46 PM
Which oil cooler do you like? HemmiGremmie Engine 1 09-21-2004 08:06 PM
Oil cooler HO 502 HDO Engine 1 07-24-2003 09:30 AM
