-   -   Need opinion...700R4 or T-400 (http://www.hotrodders.com/forum/need-opinion-700r4-t-400-a-225806.html)
my87chevrolet 11-06-2012 03:12 PM
I have a 1987 V10, 4" lift, 33", NP208, tires, i use this truck for everything, daily driver, towing, hunting, EVERYTHING. I am on my second 700R4 and its about to go out as well. I need so honest opinions and why, but i cannot decide if i want to rebuild my 700R4 again but with a Monster transmission rebuild kit, or go with a TH400. Some people even said to put in the 350 turbo...but i don't know everybody has a different opinion. What is yalls take on it...
thanks a bunch. :smash:
novafreek6872 11-06-2012 03:17 PM
IMO, build the 700 stout...you need all the gas mileage help you can get
my87chevrolet 11-06-2012 03:20 PM
not too worried about the gas milage
novafreek6872 11-06-2012 03:30 PM
Do you own a refinery? :D
Ok then the 400 will be strongest but a th350 can be built strong... probably either would work just fine
mud.man.rj 11-06-2012 04:40 PM
what trans
Don't waste your time on a 3 spd when you already have a 4spd. Just get it built right and stay with the 4spd. Has a better 1st gear too.
mud.man.rj 11-07-2012 04:28 PM
700r4
Ya it is a weaker trans than a T400 but tell Monster trans that or B/M or TCI a whole different story if you buy a properly built trans, like saying a 10 bolt is no good, sure compared to a 12 Bolt, all depends on the use of it. Drive hard then pay for quality parts or it won't last.:smash:
SSedan64 11-07-2012 09:27 PM
It can be built to handle some abuse. I'd check with a Builder who specializes in the 700R4/4L60 over Monster.
Dana >> 700R4 & 4L60E Automatic transmissions specialists - ProBuilt can put a strong package together for you.
E.Furgal 11-08-2012 07:13 AM
you are on your 3rd... you are either hard on the trans or the builder sucks.. sorry for being blunt..
you didn't list what type miles you got out of each rebuild.. ??
I'd maybe step up to a 4l80e.. basicly a th400 with a o/d
or install a th400 if your milage per gallon isn't that big of a deal..
might try not use'n o/d when tow/pull/loaded up.. o/d is the weak point in those..
I'm asumming (dangerous I know) that you have a cooler.. and the trans death is from other things than lack of servicing..
good luck... many trucks with tons of miles on those 7004r's..
but upkeep and t.v. cable adjustment have to be correct and followed..
maybe go to the 4l60e and get the v.t. cable gone..
