Need an opinion on some t-350 parts - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2007, 11:02 AM
seven1nova's Avatar
I’m attempting to build my first tranny TH350, I need opinion on this ring gear. Is it reusable or do I need to buy another one, plz take a look at the pictures I attached and let me know what you think.
ID:	20348   Click image for larger version
ID:	20349   Click image for larger version
ID:	20350   Click image for larger version
ID:	20351   Click image for larger version
Old 04-10-2007, 11:23 AM
Need an opinion on some parts
This ring gear is no good. Furthermore, the lever that engages this ring gear[located in the case] may not be in very good shape either, so you need to check it out.
Old 04-10-2007, 11:29 AM
seven1nova's Avatar
Thanks
are you talking about the parking paw, i think that is what it's called
Old 04-10-2007, 11:48 AM
Yes that is correct. Check out the end that makes contact with the ring gear. It may look a lot like the ring gear.
Check it out good, so your car will hold in park.
Old 04-11-2007, 05:00 PM
seven1nova's Avatar
2nd Opinion
Ok I got a new ring gear. I just got the tranny back from the shop, had them install new bushing. I asked about the parking paw, the guy told me it should be fine that i really didn't need to replace it. Only if I wanted to, so I took a couple of pictures so you guys can have a look, So what do you think.
ID:	20381   Click image for larger version
ID:	20382   Click image for larger version
Old 04-11-2007, 07:19 PM
junior stocker's Avatar
Just compare it to a "GOOD" one and you'll quickly decide to replace it too; the tangs are too rounded.
Old 04-12-2007, 11:46 AM
seven1nova's Avatar
Yeah I probably would but is this one good to use or not and are they easy to change out or PITA and how do you do it, the manual/Video I have don't say anything about how to do it just to change it if it's bad.
Old 04-14-2007, 04:53 PM
BigDawgsEatFirst's Avatar
400SBC4Life
Ditto, but see what the industry pro's say.
they know how much is too much
It looks too rounded to me also
Old 04-15-2007, 04:56 PM
Is'nt the parking pawl just held in the case by a pin that's retained by a small c-clip? Been a long time since I did one (powerglide racer). Seemed to me the first trans core I got was a parked car that got hit and the case was cracked internally by the parking pawl mechanism being stressed. Only knew it after tearing the thing down. They replace the whole trans and I had to start over. Been using powerglides since. BUTCH.
Old 04-16-2007, 01:05 PM
seven1nova's Avatar
Ok so how do you replace it, there's a plug that cover the pin that holds it in. Do I remove the cover looks like a small freeze plug or something then how do you remove the pin that holds the pawl in.
Old 04-16-2007, 05:33 PM
seven1nova's Avatar
Ok you guys were right so I went out and bought a new parking Pawl. Yeah I can see the difference. ( I'm starting to hate you guys making me do all this extra work J/K)
Here are some pictures but i still need to figure out how to change it.
ID:	20489   Click image for larger version
ID:	20490   Click image for larger version
Old 04-16-2007, 07:23 PM
Crosley's Avatar
Wiki Edits: 1659
it is easy on the bench.. slide the pawl forward on the pin.
Push it at an angle with a punch so it binds on the shaft(pin) , then whack the punch with a hammer.
Couple of whacks will dislodge the cup plug with the pin.
It may take a time or 2 to get the pawl to force the pin out.
clear as mud , I hope.
Old 04-17-2007, 09:43 AM
seven1nova's Avatar
Thanks Crosley
Yeah!! I got a chance to try it last night and got it out, the only thing I did different was to use an old pair of vise grip to hold onto the pawl and whack a couple of times and bam off it came. I did nick the pin but i going to grind it down and smooth it out, looks like it shouldn't be a problem.
Thanks to all who replied
Boy are parts guys stupid, or are they? MARTINSR Hotrodders' Lounge 107 04-17-2007 11:26 AM
Need Detent parts for turbo 350 Belair 57 Transmission - Rearend 9 11-29-2006 08:22 PM
hmmm 305 or 350 ??? S10_V8 Engine 6 11-15-2006 09:47 AM
Your opinion on perfect 350 Build 1stTimeDoingItRight Engine 5 04-13-2006 05:45 PM
350 Help kascsakjj Engine 7 05-22-2004 06:31 PM
