I had to look on my simmilar Central Pneumatic compressor ( 1 size bigger ) to look at the fitting. and there is a small copper tubing going into it for the unloader, and then what I think is 3/8" inverted flare going to the regulator. the other side is capped off and looks to be 3/8" NPT.. between the hardware store and the auto parts store in the brake fittings section, you should be able to make up what you need... you could get the P/N and search HF's website and order the part. probably cost a couple bucks but it'll have to come off the boat, so it would take a while
