Need a part for an air compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2011, 05:51 PM
bigdog7373's Avatar
Of course it's fast
I have the same air compressor as the one in the pic. I got it for free but it needs a part that i cant find anywhere. It is the t piece that comes out of the tank and connects to the compressor and regulator. In the pic if u look at the pic, if you look at the first gauge, its under it on the side of the tank. You can see a copper tube going into it. Its a central pneumatic. Anyone know where i can get this part?
Old 01-22-2011, 06:47 PM
Yeah, a well-stocked hardware store. It looks like a standard T fitting with a 45 deg flare. Heck, even the plumbing department at Lowes has them. I can't tell what's on the RH outlet - is that where the hose connects? You might need to get an adapter to the NPT threads on the hose.
Old 01-22-2011, 06:53 PM
bigdog7373's Avatar
Of course it's fast
Nothing connects to the right side. Just the top and left side. The thing is that the hose that connects to the top is male and half the size of the pipe that connects to the left, which is female.
Old 01-22-2011, 08:55 PM
So all you need is an elbow? Again, spend some time in the plumbing department. Adapters are easy.
Old 01-23-2011, 01:49 PM
bigdog7373's Avatar
Of course it's fast
Its not an elbow. Theres 3 inlets. I from the compressor, one to the tank, and a small one to the pressure regulator.
Old 01-23-2011, 02:08 PM
Wiki Edits: 31
I had to look on my simmilar Central Pneumatic compressor ( 1 size bigger ) to look at the fitting. and there is a small copper tubing going into it for the unloader, and then what I think is 3/8" inverted flare going to the regulator. the other side is capped off and looks to be 3/8" NPT.. between the hardware store and the auto parts store in the brake fittings section, you should be able to make up what you need... you could get the P/N and search HF's website and order the part. probably cost a couple bucks but it'll have to come off the boat, so it would take a while
Old 01-23-2011, 02:48 PM
bigdog7373's Avatar
Of course it's fast
Thank you. K think i maight me able to rig something up.
Old 01-23-2011, 05:48 PM
Old Fool's Avatar
Use a tee with fitting adapters
Old 01-24-2011, 08:06 PM
bigdog7373's Avatar
Of course it's fast
Good idea! Dont know why i never thought of that.
Eaton Compressor threatens to sue me over "Made in China" compressor post Jon Hotrodders' Lounge 190 03-06-2015 07:11 AM
Can you I.D. this part? speedydeedy Hotrodders' Lounge 5 01-23-2011 12:44 AM
Compressor part question ranman1023 Garage - Tools 3 07-21-2008 01:37 PM
Name this part Kevin45 Hotrodders' Lounge 10 01-12-2004 10:15 AM
Need a part! Gr8 '48 bow tie Hotrodders' Lounge 2 07-11-2003 06:56 AM
