Need a pigtail connector for this: - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2006, 03:29 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Hi Folks,
1966 Ford Galaxie's used to have idiot-lights for engine temperature "Cold" (Blue), as well "Hot" (Red). I want to use both guages and idiot lights on my 66 GMC truck project.
I think ALL vehicles should have a "COLD" light ... as they are very effective at making driver wait until the engine and trans have come up to temperature before driving off.
NAPA/Echlin and Blue Streak (Standard Motor Products) both still have the 2-pin sending switch available:
Echlin # TS6155
Blue Streak # TS22
Does anyone know of a molded pigtail connector that fits this?
I had a 66 Galaxie as a kid, but can't recall if it had a single molded connector, or if it just used 2 single "slide-on" connectors ... similar to the ones on the starter solenoid.
If I have to, I will order 2 single connectors ... but I'd rather have a 1-pc molded one if they came that way.
Thanks,
Don
Old 09-08-2006, 04:16 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Try a "Right Head" temp/computer sensor for a 1980 Corvette..Looks similar..
If that won't get it, take it to the local bone yard and do some "custom" test fits.
Another way to go is mini ring terminals and bolts, (note threaded terminals)
You could also try blue butt splice ends..but that's really kinda hookey..
Doc
Old 09-08-2006, 04:26 PM
poncho62's Avatar
Wiki Edits: 5
My 62 Pontiac has a cold light.......the sensor has 2 connections. Maybe one of those will fit for you. Mine has 2 separate connectors to it.
Old 09-08-2006, 04:29 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
My 67 Chryslers had the hot / cold sensor.
I too wish that all cars had those.You might be able to use the Chrys. switch and the pigail for that.
I think that they used the standard Packard56 series terms. and the connector bodies are available for those.
Bryan
Old 09-08-2006, 10:27 PM
66GMC's Avatar
Bryan
Hi Bryan,
I check the "67 Chrysler" (Newport w/383?) application as you suggested.
Originally Posted by NAPA Pro-Link
Line Code: UNI
Part Number: TS6625
Description: Temperature Sender Light Switch
Attribute Features & Benefits:Light and Gauge Type,Temperature Rating:TCS terminal off at 103°F, "R" terminal on at 243-263°F,Thread Size:1/2" x 14 NPT,Type of Packaging:Box
The "Light and Guage Type" description is a little confusing, but the "off @103F" ,and "On at 243 ... sound right.
This 67 Chrysler actually has a "cold" light?
What do you suppose "TCS" stands for?
Please advise...
Thx,
Don
PS
This is the description for the switch from my original post:
Line Code UNI
Part Number TS6155
Description Temperature Sender Light Switch
Attribute Features & Benefits:Light Type,Temperature Rating:Green light to go OFF at 102-120°F, red light to go ON at 242-264°F.,Thread Size:3/8" x 18 NPT,Type of Packaging:Box
Last edited by 66GMC; 09-08-2006 at 10:33 PM. Reason: descriptio of switch in original post
Old 09-08-2006, 10:48 PM
68 fords (LTD anyway) also had this feature. might try a salvage yard.
Old 09-09-2006, 12:24 PM
Bryan59EC's Avatar
Not sure what the TCS stands for.
Green cold light---usually on for about four minutes in the winter in Idaho.
Red hot light---only saw that come on in the Phoenix summers
I suggested this type as it may be easier to locate the pigtail connector.
I guess if some GM products had the same feature (Idon't know) you could
use that switch as well.
Chrysler and GM used the Packard56 series terminals thru the sixties so locating a connector body to fit would be easier.
I am not sure but a Back-up switch on a manual floor shift GM tranny has the same pattern for connection--
--l _ shaped---most other two term bodies are
oriented in more of an L shape
Bryan
Old 09-09-2006, 01:18 PM
66GMC's Avatar
Bryan
Yeah ... I'm thinking that a 2-prong signal flasher connector would work, too.
The next issue is that the Chrysler sender is 1/2" NPT. I think that the location that I want it on the intake manifold is 3/8" NPT. I suppose that I could just drill it out and re-thread it.
The GM sender that goes in the cylinder head (for the guage) is 1/2" NPT ... but I have read, here at HR.com, that senders for that location are purposely calibrated to "expect" 25 hotter than actual because of heat transfer from the exhaust ports.
Aw heck, I'll probably just use the Ford one ... with either individual slide-on terminals, or eyelets and nuts as suggested by Doc.
Old 09-09-2006, 01:30 PM
66GMC's Avatar
Now here's a co-inky-dink for ya...
A 62 Pontiac Catalina uses the same (TS6625) temp sender as a 67 Chrysler Newport!
Don
Old 09-09-2006, 03:19 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
TCS= Torque Converter Sender..
Doc
Old 09-09-2006, 04:42 PM
Bryan59EC's Avatar
Doc---It appears as if you have a dry sense of humor.
I like that
Bryan
Old 09-09-2006, 06:08 PM
docvette's Avatar
Wiki Edits: 12
I like that
Bryan
Doc here,
..Can't get away with nuttin nomore...
My best REAL guess would be Thermally Controlled Switch (The Normally Closed Terminal) is off at that spec..103 deg. (Cold lamp) And switches the center wiper to the "R" Terminal (Normally Open) Terminal at 243 degrees..(Hot lamp) in-between that range is an "OFF" state output.
Doc
Chevy/GM '55-'63 Stop/Tail Light Pigtail Seon Electrical 14 01-27-2006 09:33 PM
