need posi rear end info - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2008, 08:35 PM
oldguy829's Avatar
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
I have a rear end from a 55 Stude. Supposed to be a dana 44.
stamped uspat 201818 has a metal tag 43/13 (331 gears).
Shape and bolt pattern looks like a dana. can anyone confirm?
Next - what does it take to convert to a posi traction?
Old 05-15-2008, 12:26 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
I don't know about the first question.
To change from open to posi, requires
a clutch & spider unit (posi unit) to replace the spider arrangement
I guess you'll need to contact Dana & find out
what that rear is, & if there is a posi unit for it.
Good luck,
Rich
http://www.dana.com/
Old 05-16-2008, 09:37 AM
oldguy829's Avatar
Wiki Edits: 88
need posi info
I have confirmed it is a dana 44. should be a 19 spline, but I haven't opened it up yet to confirm.
I know I will need the posi unit, also new ring and pinion and new bearings, seals etc. Wondered if I also needed a new carrier, and anything else.
will a '69 Chevelle rear end fit into a '70 Chevelle? SMO'KUM UP Introduce Yourself 2 09-17-2007 08:15 AM
12 bolt posi rear end fluid 1972bigblockchev Transmission - Rearend 3 06-19-2007 10:46 AM
Converting to posi... rear end and gear ratio? Street Rod Transmission - Rearend 3 01-21-2007 08:31 PM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 06:32 AM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 11:50 PM
