Need this question answered!! - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-28-2012, 12:58 PM
Banned
Originally Posted by vinniekq2 View Post
5800 rpmx26 inch tall tire=top speed of 110 ish
6500 rpm x 29 tall tire = 135 ish top speed
a 78 camaro gets mighty lite in the nose at those speeds..
  #17 (permalink)
Old 11-28-2012, 05:23 PM
1971BB427's Avatar
Several options. You could rebuild the TH350 with a manual valve body/shift kit and you'd have a trans to shift, but just no clutch. If you want to launch a little harder add a trans brake to that build.
You could also go with either 200r or 700r4 and also a manual shift kit, then you'd have the shifting and the overdrive, plus if you went with the 700r4 you'd have a granny first gear with those 4.11 gears for a real launch!
Or go with a T56 5 speed or 6 speed and get a good hard launch, and overdrive for the highway.
Yes, your Camaro is heavy, and it takes a bit to get them moving, but I'd guess my '71 with 427 is a bit heavier and I'm running a 3.42 posi without suffering acceleration, or top end. Mine's no barely legal street car, but still runs low 12's with street tires, at around 118 mph. And it's running a TH350 built to handle BBC torque.
  #18 (permalink)
Old 11-29-2012, 09:50 AM
78 Camaro = fat heavy car,lose some weight. I put a T400 in my 80 Camaro because the T350 came apart twice. Put taller tires on the car and see how that works for you(borrow them for a day) A muncie,plus heavy leaf spring car plus 10 bolt diff plus burn outs === expensive. count on breaking spider gears,wheel hop is a possibility, The muncie will break on occasion if you dont upgrade the case.
The car is too heavy so most of the parts will eventually break,including the clutch.
How did you arrive at the 400 horse power figure?
the 400 horse power mark is what me and my engine builder settled on when i brought him my block and my 91 corvette heads......
  #19 (permalink)
Old 11-29-2012, 09:57 AM
Which would you rather have?
thank you everyone for all the answers you gave me on my other post but now i would just like to know (for a street car) would you rather have a good auto tranny or a good manual? 400 hp small block and 4:11 rear end in 1978 camaro.....let me in on what you would want to put between that motor and rear end.... name trannys and gear ratios......thanks
  #20 (permalink)
Old 11-29-2012, 11:00 AM
I'd run a turbo 400 auto and keep the 4.11's.
  #21 (permalink)
Old 11-29-2012, 11:02 AM
I'd most defanatly rather have an auto on a street car over a manual. Get a turbo 400 with a good matching converter and a good shift kit, get your shifts tuned to your car and you'll be good to go.
  #22 (permalink)
Old 11-29-2012, 11:08 AM
vinniekq2's Avatar
My corvette,I converted to a TKO 5 speed and gave a local kid the old 4 speed.I dont drag race so the standard is for fun sport driving.
For drag racing I would use a turbo 400 if the car was a regular street car and probably a powerglide if race olny.
If the car was really something to look at ,I might consider the TCI 6 speed auto.The car would have to be worth the investment.as $6,000 is a lot more than $800 for a turbo 400
How NOT to get your questions answered....... poncho62 Hotrodders Site Suggestions and Help 8 01-12-2009 03:59 PM
retired mechanic needs question answered fredma1966 Hotrodding Basics 5 01-06-2009 02:57 PM
for yall that answered the horsepower question erythnul Engine 4 08-11-2004 03:37 PM
Need some question answered Nightfire Hotrodding Basics 7 07-04-2004 05:52 PM
Need three questions answered please! sportbikeluvr Body - Exterior 9 06-21-2004 01:11 AM
