Need rear end advice - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2005, 10:25 AM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
Hello
I recently adquired a 1919 model t truck body with no frame, fenders or bed. Plans for it are mount it on a homebuilt 2x3 frame with a shortened model A bed and a '40 Ford front axel up front (reason why I'm using it is cause it was free). It'll be powered by a mostly stock 267 SBC. Here's my question, which rear-end should I use? The advice I got so far it either a Ford 8 inch or a Chevy 10 bolt rear. Which one would you think is better? Performance is secondary as price is first. It'll be a fairly light car so the 267 with a (hopefully) saginaw manual should move it along nicely. I'be been told a Ford 9 inch is overkill. Also are these rear-ends gonna stick out a lot on sides? Which one would fit best? And my last question, how do I identify them? It's a tight budget car so I'll go to the junkyard to get a cheap rear-end, so I'll need to know how to identify them.
Thanks,
Mike
Old 05-31-2005, 11:50 AM
Wiki Edits: 49
The Ford 9" would be overkill. If I were you I'd look for a rear end out of a V8 Falcon or Maverick. If you would rather have a GM rear (and one that might fit a little better) look for one out of a V8 Monza. That one should be narrow enough to fit nicely.
Some people might also suggest a rear end from an S-10 as well.
Good luck.
Old 05-31-2005, 05:12 PM
Nightfire's Avatar
Young & Idealistic
Wiki Edits: 4
I'll keep my eye out for one of those, thanks Centerline.
Does anyone know the desired width you want for a model T? It'll have a model A bed if that helps.
Thanks,
Mike
Old 05-31-2005, 06:46 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Frame rails
Mike,
Use a 2x4 frame rail..the extra stiffness will pay off for you if you ever get the money together for a hot motor..
Try looking for the rear from an S-10 4wd..I think those are a bit stronger if you can find them..
Maybe Speedway has the dimension for what they use in their kits for the rear..good to check any way..and you can measure the width of your front end hub to hub and have that in mind so the front and rear are close to one another and it won't look funny with a narrow front and wide rear..
Just a hint..
OMT
Old 05-31-2005, 07:05 PM
Jared's Avatar
I agree with OneMoreTime on the 2x4 frame rails, you could look up what the stock width is and look on google for axle widths they have them on there for ford 9" and 8" I know. I would go with a 8" or 9" you can find them any where and parts are cheap. Then later on you could up the engine and be fine too. 8" you can get a socket wrench on the bottom 3rd member bolts 9" you cant.
Old 06-01-2005, 06:57 AM
Nightfire's Avatar
Young & Idealistic
Wiki Edits: 4
Thanks for all the help, I just realized I posted this question in the wrong forum.
So I guess I'll start looking for an S10 rear-end or a Ford 8 inch then. I dont have the 40 Ford front axles yet but I've already taken a look at them. They still have the wishbones on them but no spindles or hubs.
I'll be running coilovers so I guess I'll have to make custom brackets to the rear?
I dont really wanna go with the Ford 9 inch, just because its overdone, and this car I want it to be a bit different. Also the 9 inch will cost me more than the Chevy S10 will.
Mike
Old 06-01-2005, 02:05 PM
2wd s10 rear ends are about 54.38" wide wms-wms (wheel mating surface). The 4x4 axles are 4" wider (2" each side). In the late 80's early 90's (don't remember exactly which year) they upgraded the axle shafts from 26-spline to 28-spline. If you get one out of a 98-up blazer it will come with disc brakes.
Another option is a ford 8.8" axle from a ranger or explorer. I think this would be a good choice if you want to use the 5 on 4.5" bolt pattern. The explorer axle is stronger then the ranger (31-spline) but it is still lighter then a 9" and also uses less power to turn it. They are about 2" wider then an s10 axle and 96-up explorers come with disc brakes.
Old 06-01-2005, 09:05 PM
Nightfire's Avatar
Young & Idealistic
Wiki Edits: 4
Thanks a lot. Front will get drums, it's a 40 ford axel so I'm hoping to find some finned buick brakes for it (keeping my fingers crossed), so I dont know if I want discs in the back. I'll go to the junkyard soon and I'll revive this thread then if I have anymore questions.
Thanks for all the help!
Mike
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
s-10 rear end smallblocked_S-10 Transmission - Rearend 11 06-17-2005 05:43 PM
dodge challenger in need of rear end advice. Journier Transmission - Rearend 0 05-28-2004 10:23 PM
Need advice on engine,tranny,rear end switch for 81 monte EverReady!974 Engine 12 01-02-2004 04:03 PM
Rear End Advice Needed Rick Yocum Transmission - Rearend 1 08-08-2002 04:45 PM
