need remote booster help - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2010, 02:49 AM
Don Meyer's Avatar
I made a frame for a 66 Rolls, removed the sub frame from the car & bolted
it to the new frame. Installed a crate motor/700r4/9".
I then put the project aside 3 yrs ago because I did not have room for a power boosted on the frame & did not know which direction to go to get power brakes.
Does any one know here I can get directions on how to mount a remote booster(trunk mount type) for a disc/drum system. Also where can I get
one with out paying a arm & leg.
Thanks Don
Old 08-20-2010, 05:20 AM
SSedan64's Avatar
remote mount brake booster
http://www.google.com/search?hl=en&s...AAAKoEBU_QI3jj
Old 08-20-2010, 06:38 AM
What about the kind of booster that runs off your power steering pump? They are a lot smaller than the standard vacuum assist kind. Check out Classic Performance Products web site. They sell the system.
Old 08-20-2010, 08:33 AM
Don Meyer's Avatar
There also is no room for a hydroboost, just room for a master cylinder.
I also did a google search & it was of little help.
Anyone have experience with a remote booster.....There must of been a car
or small truck that used it.
Don
Old 08-21-2010, 06:28 AM
I ran a remote booster on my 36 Pickup for years. It was mounted on a bed cross member. The plumbing was basically from the MC to the booster then to the appropriate wheels. I used a small vacuum canister with a check valve in the line to the booster. When I purchased the booster, I had a choice between a large and small one and selected the small booster. I think the booster came from Chassis Engineering, but that was over thirty years ago when I installed it and the old memory is no longer a steel trap.
Trees
master and booster problem/c5 conversion chevelle327C5 Suspension - Brakes - Steering 2 01-09-2010 09:13 AM
Remote Power Brake Booster - 62 Impala Wagon glide85 Suspension - Brakes - Steering 12 12-24-2009 09:18 AM
I need a remote power booster nprfan Suspension - Brakes - Steering 10 10-20-2005 02:08 PM
Single Diaphragm Booster Slant3 Suspension - Brakes - Steering 2 10-06-2005 07:37 AM
brake booster size pigjamelectric Suspension - Brakes - Steering 3 05-08-2005 08:44 PM
