Need to rig up a park brake in the cab... - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2006, 03:42 PM
murrsue's Avatar
Last journal entry: 57 pickup 8.8 rear axle install
I need to rig up a park brake in the cab of a 57 Chev truck. I installed a Volare clip and an 8.8 rear out of a Ranger. I had to remove the original 57 park brake handle and linkage. I have the park cables from the 8.8 run forward. Just wondering what my option are for a junkyard park brake lever. The truck will have a bench seat so a floor mounted park brake in the center won't work. I was wondering about a floor mount lever on the floor beside the drivers seat or a t handle pull type twist to release under the dash style like my old 65 Ford truck had. Not too keen on the regular GM foot pedal and release handle type as it might be a more difficult install (or will it?). Any ideas?
murray
Old 08-30-2006, 10:56 PM
I like to use this type ... they came in 39 to 48 Ford passenger cars and Pickups to the early 60's ... at least ... easy to adapt ... and does not take up much room ...
I have one in my 32 Roadster and one in my 32 3W ... both from a 56 F-100 ...
I took the photo from eBay ... hint, hint
Old 08-31-2006, 07:17 AM
murrsue's Avatar
thanks Deuce
that looks good!
murray
Old 09-02-2006, 08:48 AM
On my 57 chevy truck, I put the ebrake lever on the floor, just outboard of the driver's seat. Bill
Old 09-03-2006, 08:41 AM
murrsue's Avatar
I was thinking of that spot for it...
....have you got a picture? What donor did you get the handle from? Murray
murray
Old 09-03-2006, 08:19 PM
Sorry, no pics, sold it several years ago. I bought an inexpensive handle from an ad in StreetRodder magazine, but any salvage yard handle with a lever on the underside will work fine- I was too lazy to go take one out. A couple of bolt holes and a slot and that's all there is to it-drill up from underneath to get the clearance with the framerail. Bill
Ford Galaxie Disc Brake Conversion CrashFarmer2 Suspension - Brakes - Steering 5 04-10-2010 04:52 PM
Taurus Hangs Up in Park Position... awbazar Suspension - Brakes - Steering 2 06-19-2006 10:51 AM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
brake question Ratoflic Suspension - Brakes - Steering 1 09-29-2005 10:32 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
