Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need a ruler...decimal-inch
  #30 (permalink)
Old 03-15-2011, 03:34 PM
MARTINSR MARTINSR is offline
Let's just forget about the measuring tool you use for a minute and look at your problem or possible problem. What makes you think you have a problem with your body stucture? And I have to tell you that everything you need can be done without those specs. Most often simply cross measuring will tell you everything you need.
