Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need to run long length of pipe from air compressor
  #21 (permalink)
Old 06-26-2009, 10:33 AM
001mustang's Avatar
001mustang 001mustang is offline
Sloped lines
Originally Posted by robs ss
I would stay away from the underground line if you can, heres a drawing of what you need to do to remove moisture generated by your compressor.
http://www.1969supersport.com/draw1.html
Rob
That is a good drawing. I like the exaggerated slope.
The lines should be sloped as much as practical to assure water is actually drained. I have seen specs of 1/4" per foot which can lead to water build up like previous poster said.
I prefer to slope line to compressor to assure that OIL as well as water drains into compressor tank.
One problem I saw with the drawings is the first leg from compressor outlet is not sloped and the pressure gauge (PI) is susceptible to flooding. A flooded PI will surely get freeze damaged if ambient temp drops below freezing. Must mount PI above water level.
