Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need to run long length of pipe from air compressor
  #30 (permalink)
Old 06-27-2009, 01:11 PM
001mustang's Avatar
001mustang 001mustang is offline
Originally Posted by 001mustang
1/2" copper will be sufficient if you use only one tool at a time. You can run a healthy sand blaster or paint gun using the 100' 1/2 Cu line. You can run 3/4" Cu if you have overkill tendencies.
If you run one tool at a time you will be hard pressed to use all the air a 100ft 1/2" line can provide, regardless of compressor size..
http://www.goodyearrubberproducts.co...g1.Page528.pdf
100' 1/2" pipe will flow 54 SCFM at 100 PSI with a 10% DP.
