Need Shifter for Borg Warner T-10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2007, 03:37 PM
Hello,
I bought, what I believe is a Borg Warner T-10 transmission. Problem is, I found that there are all different kinds of Borg Warner T-10 transmissions. I went to Hurst's website and printed out their Transmission ID chart to find out exactly which one I have. I then called Hurst directly and told them this. They said the only shifter they have that is compatible is a drag racing shifter, hard to believe. Can anyone provide any info on this tranny or let me know what kind of shifter is available for this? This will be going into a '65 fastback.
The numbers on the tranny are:
T10H-1
W.G. DIV
W-1
T10H-7B
WG DIV
Thanks,
W
Old 04-06-2007, 05:57 PM
Photos of the trans and the shifter mounting area will help a bunch.
Old 04-08-2007, 05:59 PM
RippinRon's Avatar
Take a look here
Old 04-09-2007, 10:33 AM
Pics
Here are a couple pics of my tranny.
As far as the ID chart, I went to Hurst Shifters and found mine to be the 415:
http://www.hurst-shifters.com/catalo...nltransID2.pdf
ID:	20330   Click image for larger version
Brake lights switch oldsmo Electrical 4 10-19-2006 11:23 AM
Pro 5.0 Shifter for a GM T-56 trans - Anyone tried it?? hotrodf1 Transmission - Rearend 2 05-22-2006 07:18 AM
What automatic shifter is good novadan Transmission - Rearend 3 02-23-2006 10:45 PM
F-body differentials, 9 bolt Borg Warner vs. GM 10 bolt Mad Maggot Transmission - Rearend 8 02-17-2005 08:02 PM
Automatic shifter in pickup floor? newchevyman Transmission - Rearend 5 09-02-2003 06:48 PM
