NEED TO SHORTEN MY DRIVESHAFT - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2002, 12:11 PM
Post NEED TO SHORTEN MY DRIVESHAFT
I HAVE JUST MOVED THE ENGINE AND TRANNY BACK 4" ON MY 1936 FORD COUPE WITH A 350 - 350 TRANNY AND 8" FORD REAREND.
I'M GOING TO HAVE TO SHORTEN MY DRIVESHAFT, DO YOU GUYS WANT TO GIVE ME ANY THINGS TO WATCH OUT FOR OTHER THAN MAKING SURE JOINTS ARE IN PHASE. ALSO WHAT IS THE CORRECT WAY TO MEASURE FOR THE PROPER DRIVESHART LENGTH.
BEFORE I DO CUT IT I'M GOING TO HAVE TO CHECK BOTH THE ENGINE ANGLE AND REAR ANGLE TO BE SURE I DON'T HAVE TO MUCH UNCANCELLED ANGLE.
THANKS
BOMO
Old 11-02-2002, 02:42 PM
Post
BOMO, sounds like you are moving right along. To measure the length, put the yoke, less the ujoint and drive shaft, in the transmission and push all the way in and back out 1" . Measure from the center line of the front and rear yokes. this becomes the length of your finished drive shaft from shaft yokes centerlines. I recommend you take your shaft to a drive line company or a good machine shop and let them cut or make your drive shaft, unless you are an experienced machinest with well equiped shop. Check Yellow pages or other street rooders in your area. More ways to skin a cat. do the sam thing with the front yoke, then measure from the back surface of the rear yoke where the unjointfastens and measure to the back part of the front yoke ujoint hole. (same distance as above)
Old 11-02-2002, 02:50 PM
Post
Woops, I'm assuming you have a drivshaft made up for the 350 tranny and Ford rear. If not, you will need to tell the drive line guys that you are mixing and matching GM front and Ford rear. You may want to check your pinion shaft ofset and compare with where the tranny shaft is. Both should be dead centered in the frame for the best results. You just don't have the room to move the engine/tranny more than a 1/4 inch left tor right of center because of the X member. Now you can do some heavy modification, but the X member strength is the heart of the old Ford frames. May want to consider Chevy rear.
Old 11-02-2002, 03:45 PM
Post
WELL I HAVE COMPLETELY CUT THE X MEMBER OUT LAST WEEK AND HAVE FABRICATED A MUCH WIDER X FRAME TO ACCOMADATE SLIDEING THE ENGINE AND TRANNY BACK 4" I KNOW THIS HAS TO BE STRONG AND THAT IT'S THE HEART OF MY FRAME. I FEEL LIKE I DID A SUPERD JOB ON REDESIGNING IT AND WELDING IT ALL TOGETHER. IN FACT I'D BET I CAN LIFT THE CAR BY THE CENTER SECTION.
MY BACKGROUND YEARS BACK WAS IN THE MACHINE TOOL INDUSTRY, ALTHOUGH FOR THE LAST 30 YEARS I HAVE BEEN A SAFE CRACKER
I'M JUST A LITTLE FUZZY ON YOUR EXPLANATION OF HOW I MEASURE MY DRIVESHAFT LENGTH, AND YES I DO HAVE THE OLD ONE THAT IS TO LONG
THANKS FOR YOUR POST AND I'LL TRY AND GET BACK TONIGHT TO SEE IF YOU LEFT ME A POST
BOMO
Old 11-03-2002, 07:50 AM
New Member
Post
hope u dont mind me asken y u moven it bac anyway
Old 11-03-2002, 09:46 AM
Post
NOT AT ALL MATT.
AFTER I HAD THE BODY IN PLACE AND REAR FENDERS ON AND RUNNING BOADS AND WAS TRYING TO FIT THE GRILL AND FT FENDERS AND RADIATOR IN I FOUND THAT WITH AN ELECT. FAN I WAS ABOUT 2 1/2" TO FAR FORWARD WITH THE ENGINE EVEN WITH A SHORT WATERPUMP PLUS I HAD TONS OF ROOM BEHIND THE ENGINE TO FIREWALL
Old 11-04-2002, 03:32 PM
axle bastard's Avatar
you're killin me buck!
Post
if the tranny moves 4" and the driveshaft is in the right spot to begin with, you should be able to take 4" out of the tube with no trouble.
once you stuff the yoke into the tube, you have to straighten it, remember, the joint is the center of rotation.
you can have a drive line shop replace the gm yoke with one to accept a square joint at the pinion, or get a conversion joint.
i would find a driveline shop.
i work at one and have seen the d.i.y.s. drive shafts. i wouldn't put them in my car.
good luck,
Josh
Old 11-05-2002, 04:35 PM
New Member
Post
[quote]Originally posted by bomo:
<strong>NOT AT ALL MATT.
AFTER I HAD THE BODY IN PLACE AND REAR FENDERS ON AND RUNNING BOADS AND WAS TRYING TO FIT THE GRILL AND FT FENDERS AND RADIATOR IN I FOUND THAT WITH AN ELECT. FAN I WAS ABOUT 2 1/2" TO FAR FORWARD WITH THE ENGINE EVEN WITH A SHORT WATERPUMP PLUS I HAD TONS OF ROOM BEHIND THE ENGINE TO FIREWALL</strong><hr></blockquote>
Not to mention the better handling
Cheers
Dale.
